    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 110.4k Views 14 Watching
    • samuel_tS
      samuel_t
      @jql said:
      I have tried the plugin and got the following errors:
      Windows can't find 'nginx'...
      Is it a first time install or an update?
      If it's an update: Open SketchUp Extension Manager. Disable PBR plugin before uninstall it. Reinstall it.
      Let me know if problem persists πŸ˜‰
      • JQLJ
        JQL
        It's a first time. Pbr v1.2.4
        Sketchup 2018
        www.casca.pt
        Visit us on facebook!
        • samuel_tS
          samuel_t
          Sketchup 2018
          Operating system: Windows 10?
          1. Open Windows's File Explorer.
          2. Goto %APPDATA%\SketchUp\SketchUp 2018\SketchUp\Plugins\pbr\Web Server
          3. Do you see the file nginx.exe?
          • samuel_tS
            samuel_t
            @jql said:
            Also, I found you removed support for emissive materials, which would be a shame, as I use them for all my lighting applications in Thea for Sketchup and would find them cool to test on this pbr plugin.
            I opened an issue for this: Emissive materials don't glow. It would be great if a GLSL expert could help.
            • JQLJ
              JQL
              I'm afk today (phone here) but I'm on win10 and I have checked before that the nginx.exe file was there, though I don't know if that was the exact path.
              www.casca.pt
              • samuel_tS
                samuel_t
                1. Restart computer. Don't open SketchUp for now!
                2. Open Windows's File Explorer.
                3. Goto %APPDATA%\SketchUp\SketchUp 2018\SketchUp\Plugins
                4. Delete pbr.rb file and pbr directory.
                5. Download and install SketchUp PBR plugin again.
                6. Close SketchUp.
                7. Reopen SketchUp.
                If problem persists: consider opening an issue here.
                • JQLJ
                  JQL
                  Will do...
                  www.casca.pt
                  • samuel_tS
                    samuel_t
                    @filibis said:
                    Hi Samuel, interesting plugin, nice to see PBR and Gltf related extensions πŸ™‚
                    Hi Filibis πŸ˜„ Thanks for your interest in this plugin.
                    @filibis said:
                    But i couldn't operate normal map.
                    Normal map must be set in PBR Material Editor. Does this info helps you enough?
                    @filibis said:
                    And didn't understand where you put those 2 'base color' textures you provided.
                    Reef demo model is made of two faces, two materials and three textures:
                    Sea normal map texture is set on Sea material in PBR Material Editor.
                    Sea base color texture is set on Sea material in Materials Tray.
                    Sea material is applied to Sea face.
                    Undersea base color texture is set on Undersea material in Materials Tray.
                    Undersea material is applied to Undersea face.
                    @filibis said:
                    Also that would be great if you let normal map strength to be adjusted and option to add metallic & roughness maps as well if possible.
                    I see no problem about adding Normal map scale (strength) in PBR Material Editor.
                    Update: Since PBR plugin v1.2.5, normal map strength is editable and rendered πŸ‘
                    Metallic and roughness maps must be packed in one map. So it's not easy for user...
                    Update: Since PBR plugin v1.2.4, metallic-roughness (packed) map is supported πŸ‘
                    • samuel_tS
                      samuel_t
                      I'm very happy πŸ˜„ to announce release of v1.2.5.
                      Features:
                      • Control camera with a standard gamepad in Viewport.
                        Plug. Move with left stick/pad. Look around with right stick.
                        It works with Microsoft Xbox One controller. Tell me if it works with other controllers πŸ˜‰
                      • Normal map scale (strength) renders in Viewport.
                      Bugfixes:
                      • Fix zoom (wheel) bug in Viewport impacting only Firefox.
                      ❗ As part of an update, remember to disable plugin before uninstalling-reinstalling it.
                      • samuel_tS
                        samuel_t
                        @jql said:
                        The problem is that a sketchup material hasn't got a direct link to textures residing on disk. So, if I change a texture like color, normal or metal-roughness map, it won't refresh. Or, will it?
                        No. Texture is embedded. You must update manually SketchUp material if you change texture on disk.
                        Linking textures can produce late errors like "missing file". πŸ˜• I will think on this.
                        • JQLJ
                          JQL
                          I did what you suggested. Erased the pbr plugin and folder from my appdata's plugins folder, restarted everything and installed, following all your suggestions.
                          Still no good with 1.2.5:
                          www.casca.pt
                          • samuel_tS
                            samuel_t
                            @jql said:
                            Hi JQL, please follow these new instructions:
                            1. Close SketchUp if it's open.
                            3. Go to %APPDATA%\SketchUp\SketchUp 2018\SketchUp\Plugins\pbr
                            4. Right click on web_server.cmd file. Choose "Edit" in contextual menu.
                            5. Replace this line:
                            cd %~dp0 && cd Web Server
                            by this line:
                            cd /d "%~dp0%Web Server"
                            1. "File" > "Save".
                            2. "File" > "Exit".
                            3. Open SketchUp.
                            4. "Extensions" > "Physically-Based Rendering" > "Open Viewport".
                            5. Do you see SketchUp model in PBR Viewport?
                            • samuel_tS
                              samuel_t
                              Today, I think it's better to implement glTF KHR_lights extension. So PBR plugin users could:
                              • Add and place lights in SketchUp (Maybe as hidden geometry? I'm looking for solutions.),
                              • Set light type (point, spot, etc.) and properties (color, intensity, etc.) again in SketchUp,
                              • Export lights (embedded in glTF file) to PBR Viewport and possibly to other platforms...
                              • samuel_tS
                                samuel_t
                                @jql said:
                                It's easier for most users to have a separated roughness and metallic maps as they are very common, instead of the metallic-roughness map required by the plugin. is there any chance the separated maps could be implemeted?
                                ~~I agree it's easier but it's not so much long to pack metallic and roughness maps in third-party software. For example, it takes less than one minute in Photoshop following these instructions:
                                1. Open roughness map in Photoshop.
                                2. Convert Grayscale to RGB Color.
                                3. Unlock (roughness) layer.
                                4. Select (roughness) layer. Open Blending options.
                                5. Uncheck all Channels except G(reen).
                                6. Place Embedded... metallic map.
                                7. Select metallic layer. Open Blending options.
                                8. Uncheck all Channels except B(lue).
                                9. Save as... metallic-roughness map.~~
                                Update: Since PBR plugin v1.3.0, Metallic and Roughness maps are separated in PBR Material Editor. πŸ˜‰
                                • JQLJ
                                  JQL
                                  @samuel_t said:
                                  [*]Metallic & Roughness maps are separated in Material Editor.
                                  Good news indeed. Will try it again.
                                  www.casca.pt
                                  • samuel_tS
                                    samuel_t
                                    Good news! PBR plugin becomes really handy with the new version (1.3.0).
                                    Features
                                    • Change environment map from SketchUp "Extensions" menu.
                                      Tip : Changing environment map changes ambient light map.
                                    • Metallic & Roughness maps are separated in Material Editor.
                                    • Access online help document translated in FR from Viewport.
                                    Bugfixes
                                    • Fixes pan (middle button) control issue in Viewport on Firefox.
                                    • Fixes a little gamepad control bug. Improves maybe performance.
                                    • samuel_tS
                                      samuel_t
                                      Next PBR plugin version will include a (micro) library of royalty-free PBR materials.
                                      These will be available in "Materials" tray. Render-example with "Wooden Palisade 01":
                                      Wooden Palisade 01
                                      This should allow new users of plugin to become familiar with PBR materials.
                                      • N
                                        nlipovac
                                        Hi, I have one question.
                                        What is stopping you in developing this plugin as synced rendering plugin for Sketchup (or maybe as an overlay to SU window)? Is this far-fetched for me to think like this?
                                        • samuel_tS
                                          samuel_t
                                          At dev. beginning, I've thinked about a PBR Viewport synced with SketchUp...
                                          That implies using internal browser but external browser is more up-to-date.
                                          • JQLJ
                                            JQL
                                            Thea has viewport rendering which, for single monitors brings sketchup to life. Your plugin, as it is realtime, would be amazing with viewport rendering.
                                            www.casca.pt
                                            • 2 / 6
