π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Suggest a good window maker plugin.
please suggest a good window maker plugin. I use windowizer 4 but it does not create frames. I am not able to load rubysoft's window and frame framer because of some plugin error. Please suggest some other plugin.
To add to the above (seriously check out Flex Components).
Free:
- WinDoor does doors and windows
Paid:
- WinDoor**+** does doors and windows, not to be confused with the above even though it's from the same developer
- Window**+** only does windows, from the same developer as the above two
I seriously doubt that these will work on your pre-6 version (as per your profile) of SketchUp.
