    Attribute "FACEAREA" 1.550003 off?
    Scheduled Pinned Locked Moved Dynamic Components
    3 Posts 2 Posters 8.2k Views 2 Watching
      Mikar
      Hi folks,
      in a component I want to use the attribute "FACEAREA" for using in a report. But for a face with the dimension e.g. 1x1m instead of yielding the expected result 1m² it produces a result off by factor 1.550003. Is this a bug? Please see image attached to see my problem. (I know I could amend that through deviding the result by 1.550003, but I would like to now why this happens). Thank you!
      Cheers
      Mikar
      facearea-problem
        pcmoor
        facearea returns inches, therefore you need to convert it, 2.542.54 gives sq inches to sq cm then sq cm to sq m then /10000
          Mikar
          Ah, I see! Thank you for explaining!
          Cheers
          Mikar
