    Referencing DWG in Sketchup and export to GE
    Scheduled Pinned Locked Moved Google Earth
    8 Posts 4 Posters 18.4k Views 4 Watching
      jex83
      Dear Forum,
      I have a georeferenced dxf-file (GK-Zone 2, EPSG 31466) and I want to get it into Sketchup to export it to GE. The location is also correct, tested it in QGIS.
      If I directly import it, Sketchup will screw the geolocation. And if I get a "reference point" in my dxf and transfer this point to WGS84 and use it as origin point in SKP, the location and the dimensions seems to match, but the model is rotated for roughly 2-3 degrees. And when I transfer the dxf in QGIS to WGS84 and to later on the same, I have the same problem.
      Does anybody know what has to be adjusted in the procedure?
      Or is there a more simple way to get a referenced acad-file referenced into sketchup?
        jex83
        Or just asked generally: how can I "transfer" a geographic reference while importing a 3D-model from another source ?
          jex83
          anyone? never ever had anybody else this problem?
            alpro
            I find getting any georefenced data into SU a PIA requiring some kind of work arounds. Why don't you use 2 reference points so then you can rotate your data?
              jex83
              hi alpro,
              thanks for the response. what do you mean by work arounds...do you have any example?
              the problem with two reference points is, that this doesn't work for instance if you have an underlying raster-satelitte image.
              and sorry for the question, but what is PIA?
              • pbacotP Offline
                PITA
                  jex83
                  @pbacot ah ok, got it πŸ˜‰
                  • SJS66S Offline
                    SJS66
                    @pbacot said:
                    PITA
                    Ha, hate to say it but I had to google it....lol.
                    Just to save other dummies like me doing the same PITA = Pain In The Arse
                    πŸ˜›
