    Double Offset
    8 Posts 4 Posters 1.7k Views 4 Watching
    • PixeroP Offline
      Pixero
      Is there a plugin that works like the offset tool but offsets the edge to both directions at once?
        samnorth
        Perhaps Offset Loops [hidden] in dropdown menu of Quad Face Tools? Use Control key to get the dual offset. I think TT said previously it's still in development and it's not very robust.
        tut here from Winning with SU
        https://www.youtube.com/watch?v=1fwkI_shOcQ&t=641s
          Sure! πŸ˜„
          By Sdmitch : MULTIPLE Offsets has this function inside! And many more! πŸ˜‰
          • PixeroP Offline
            Pixero
            Thanks for the ideas. The Offset loops keep crashing for me and the multiple offset script isn't in "realtime" like the offset tool in SU but I'll look into them.
              Maybe you can ask Sdmitch to modify its plugin for have repetition of the function at each new selection ?
              • CadFatherC Offline
                CadFather
                TIG's offset can do it - i modified the code to repeat the steps one positive and one negative values. works well, though there are some odd imprecisions.
                https://sketchucation.com/forums/viewtopic.php?p=331303#p331303
                let me know if you want the code pasted in too
                • PixeroP Offline
                  Pixero
                  Yes please post the modified code.
                    CadFather
                    hope TIG is ok with it:
                    main 2 routines:
                    @@dist=nil
                     def initialize(dist=nil)
                       @toolname="extrudeEdgesByOffset"
                       if dist==0
                         puts 'Extrude Edges by Offset' + '; Offset cannot be 0.'
                         return nil
                       end#if
                       model=Sketchup.active_model
                       ss=model.selection
                       edges=[]
                       ss.each{|e|edges << e if e.class==Sketchup;;Edge}
                       if not edges[1]
                         if not dist
                           UI.messagebox('Extrude Edges by Offset') + ('; Must Select >=2 Edges.')
                         else
                           puts 'Extrude Edges by Offset' + '; Must Select >=2 Edges.'
                         return nil
                       end#if
                       verts=[]
                       edges.each{|e| verts << e.vertices}
                       verts.flatten!
                       verts.uniq!
                       pts=[]
                       verts.each{|v| pts << v.position}
                       cop=true
                       vec=Geom;;Vector3d.new(0,0,0)
                       edges[0..-2].each_with_index{|e,i| vec=e.line[1].cross(edges[i+1].line[1])}
                       vec=Z_AXIS.clone if vec.length==0 ### all in line
                       plane=[pts[0],vec]
                       pts.each{|p|
                         if not p.on_plane?(plane)
                           cop=false
                           break
                       if not dist
                         if not cop
                           UI.messagebox('Extrude Edges by Offset') + ('; Edges must be coplanar.')
                           return nil
                         @@dist=0.to_l if not @@dist
                         Sketchup;;set_status_text(("Extrude Edges by Offset")+"; "+("Distance; "), SB_PROMPT)
                         results=inputbox(["Distance; "],[@@dist],"Extrude Edges by Offset"+"...")
                         return nil if not results
                         if results[0]==0
                           UI.messagebox('Extrude Edges by Offset'+'; Offset cannot be 0!'+"\n"+"Try again"+"...")
                           return nil if not results or results[0]==0
                         end#if
                         @@dist=results[0]
                       else ### dist passed as arg
                         if not cop
                           puts 'Extrude Edge by Offset'+'; Edges must be coplanar.'
                           return nil
                         @@dist=dist.to_l
                       end#if
                       model.start_operation("Extrude Edges by Offset"+' '+@@dist.to_s)
                       dist=@@dist
                       group=model.active_entities.add_group()
                       ents=group.entities
                       if edges.length==verts.length ### looped
                         tface=ents.add_face(pts)
                    	 fverts=tface.outer_loop.vertices
                    	 fpts=[]
                    		0.upto(fverts.length-1) do |a|
                    			vec1=(fverts[a].position-fverts[a-(fverts.length-1)].position).normalize
                    			vec2=(fverts[a].position-fverts[a-1].position).normalize
                    			vec3=(vec1+vec2).normalize
                    			if vec3.valid?
                    				ang=vec1.angle_between(vec2)/2
                    				ang=180.degrees if vec1.parallel?(vec2)
                    				vec3.length=dist/Math;;sin(ang)
                    				t=Geom;;Transformation.new(vec3)
                    				if fpts.length > 0
                    					if not (vec2.parallel?(fpts.last.vector_to(fverts[a].position.transform(t))))
                    						t=Geom;;Transformation.new(vec3.reverse)
                    				fpts << fverts[a].position.transform(t)
                    	  nface=ents.add_face(fpts)
                          tface.erase! if tface.valid? and dist>0
                          nface.erase! if nface.valid? and dist<0
                          face=nil; ents.each{|e|face=e if e.class==Sketchup;;Face}
                          face.reverse! if face.normal.z<0
                          ol=face.outer_loop
                          verts=ol.vertices if dist<0
                          il=(face.loops-[ol])[0]
                          verts=il.vertices if dist>0
                          verts.each_with_index{|vert,a|
                                    vec1=(verts[a].position.vector_to(verts[a-(verts.length-1)].position)).normalize
                    				vec2=(verts[a].position.vector_to(verts[a-1].position)).normalize
                    				if vec3.valid?
                    					ang=90.degrees if vec1.parallel?(vec2)
                    					vec3.length= -dist/Math;;sin(ang)
                                        p=verts[a].position
                    					pt=p.transform(t)
                                        ents.add_line(p,pt)
                          tr=Geom;;Transformation.new()
                          len=ents.length
                          len.times{ents.intersect_with(true, tr, ents, tr, true, ents.to_a)}
                          cedges=[]; ents.each{|e|cedges << e if e.class==Sketchup;;Edge}
                        else ### open ended
                          edges.each{|e|ents.add_line(e.start.position, e.end.position)}
                          edges=ents.to_a
                          es=[]
                          ee=[]
                          se=[]
                          edges.each{|e|
                            if not e.start.edges[1]
                              es=e.start
                              ee=e.end
                              se=e
                              break
                            elsif not e.end.edges[1]
                              es=e.end
                              ee=e.start
                              se=e
                              break
                            end#if
                          nedges=[se]
                          verts=[es,ee]
                          (edges.length-1).times{
                            edges.each{|e|
                              next if nedges.include?(e)
                              if e.start==ee
                                verts << e.vertices
                                ee=e.end
                                nedges << e
                              elsif e.end==ee
                                verts << e.vertices
                                ee=e.start
                                nedges << e
                          verts.flatten!
                          verts.uniq!
                          opts=[]
                            if a==0 #special case for start vertex
                    				v=verts[a].position.vector_to(verts[a+1].position).normalize
                    				f=dist/dist.abs
                    				t=Geom;;Transformation.rotation(verts[0].position, vec, 90.degrees*f)
                    				vec3=v.transform(t)
                    				vec3.length=dist.abs
                    				opts << verts[a].position.transform(vec3)
                    	    elsif a==verts.length-1 #special case for end vertex
                    				v=verts[a-1].position.vector_to(verts[a].position).normalize
                    				f=dist/dist.abs
                    				t=Geom;;Transformation.rotation(verts[a].position, vec, 90.degrees*f)
                    				vec3=v.transform(t)
                    		else
                    				vec1=(verts[a].position.vector_to(verts[a+1].position)).normalize
                    				if vec3.valid?
                    					if not vec2.parallel?(opts[-1].vector_to(verts[a].position.transform(t)))
                    					opts << verts[a].position.transform(t)
                    		end#if
                          begin
                            nedges=ents.add_edges(opts)
                          rescue
                            nedges=[]
                          pts=[]
                          verts.each{|v|pts << v.position}
                          ents.erase_entities(edges)
                          begin
                            edges=ents.add_edges(pts)
                          rescue
                            edges=[]
                          pts.each_with_index{|p,i|ents.add_line(pts[i],opts[i])}
                          len=ents.length
                          cedges.length.times{
                            ents.to_a.each{|e|
                              next if e.class!=Sketchup;;Edge or not e.valid?
                              e.find_faces
                          ents.to_a.each{|e|e.reverse! if e.class==Sketchup;;Face and e.normal.z<0}
                        end#if
                        model.commit_operation
                    # CREATE  REVERSE GROUP
                         model.start_operation("Extrude Edges by Offset - Reverse Side"+' '+@@dist.to_s)
                       dist=@@dist*-1
                       ents=group.entities
                    	 fpts=[]
                    			if vec3.valid?
                    				if fpts.length > 0
                          ol=face.outer_loop
                    				if vec3.valid?
                                        p=verts[a].position
                    					pt=p.transform(t)
                                        ents.add_line(p,pt)
                          len=ents.length
                        else ### open ended
                          edges=ents.to_a
                          es=[]
                          ee=[]
                          se=[]
                          edges.each{|e|
                              es=e.start
                              ee=e.end
                              se=e
                              break
                              es=e.end
                              ee=e.start
                              se=e
                              break
                            end#if
                          nedges=[se]
                          verts=[es,ee]
                            edges.each{|e|
                              if e.start==ee
                                verts << e.vertices
                                ee=e.end
                                nedges << e
                              elsif e.end==ee
                                verts << e.vertices
                                ee=e.start
                                nedges << e
                          verts.flatten!
                          verts.uniq!
                          opts=[]
                    				f=dist/dist.abs
                    				vec3=v.transform(t)
                    				f=dist/dist.abs
                    				vec3=v.transform(t)
                    		else
                    				if vec3.valid?
                    		end#if
                          begin
                          rescue
                            nedges=[]
                          pts=[]
                          begin
                          rescue
                            edges=[]
                          len=ents.length
                            ents.to_a.each{|e|
                              e.find_faces
                        end#if
                      Sketchup.send_action("selectSelectionTool;")
                      end#def
