    TreeIt : Free tree generator
    15 Posts 8 Posters 12.1k Views 8 Watching
      Tree generator (only Windows) with settings! Β πŸ™‚
      (There are some trees yet done! Export OBJ, dbo, x:)
      No need to press the "Generate" button unless you put branches and leaves! πŸ€“
      TreeIt | Tree Generator
      (www.evolved-software.com)
      And you can of course load any PNG images with transparent background as "leaves"!
      (even if not indicated in the drop-down menu files)
      If you want to put native dds formats (Direct Draw Surface) you will have to use PaintNet to create some!
      https://s6.postimg.org/bkz8huojl/GIF_hypo.gif
        sofie9536
        very thanks, fine
        • McGyverM Offline
          McGyver
          Thank you Pilou!
          [Visit My ShareCG Freebie Gallery](http://www.ShareCG.com/pf/full_uploads.php?pf_user_name)
          • JQLJ Offline
            JQL
            Looks good but doesn't work on my system unfortunatelly.
            www.casca.pt
            Visit us on facebook!
              kaas
              The size of leafs seems way off... Also, whats the triangle count of the trees? 1k 10k 100k?
              • StinkieS Offline
                Stinkie
                Cool! Thanks for the heads up, Pilou. πŸ‘
                  1k 10k 100k?
                  Only depends of what you define as parameters! πŸ˜‰
                  My red hypo-tree above OBJ + Texture mtl files = 585 kb
                  and compressed 143 Kb! πŸ˜‰
                  Hypo.zip
                  • PixeroP Offline
                    Pixero
                    Has anyone found a way of having more than 250 leaves?
                      Would make fur by component do the trick?
                        @pilou said:
                        1k 10k 100k?
                        Thanks very much.
                          In Menu Leaves / Dupplicate layers any times you want! (9 Max) πŸ˜‰
                          So 250 * 9 = 2 250 leaves! πŸ€“
                          • PixeroP Offline
                            Pixero
                            Yeah, but even 2250 leaves are not much if your going for something that look real. All examples have the twigs and leaves as an image plane. Seem to be more for real time games and such.
                              Tree It is an easy to use and powerfull real time 3d tree generator for the simple creation of your very own 3d tree models for your dark basic pro and dark GDK apps and games. All Tree It model exports are 100% free to use with any engine and project, whether it's darkbasic or unreal 4.
                              Maybe you can take png "images" with many leaves ?
                              • McGyverM Offline
                                McGyver
                                You could do as I believe Pilou is suggesting, and perhaps instead of using images of single leaves, use images of smaller branched groups... This might not be too useful with trees like maples, where the spacing of the leaves is uniform and a bit distant, but for certain oaks where the leaves are closer together and more irregularly placed, it works well.
                                I made a PNG in Photoshop once using images of a bunch of diffent oak leaves I photographed and connected them using some thin branch images... It was a bit of work, but it allowed for a fuller looking tree that needed fewer leaves.
                                  Seeems there is a new version 7 11 2018
                                  Treeit
                                  πŸ’š
                                  https://2img.net/h/s6.postimg.cc/bkz8huojl/GIF_hypo.gif
