Section plane not showing what should be
there are few areas that im having problems with the section plane.
- the 2 upper rooms arnt showing as cuts only few deatail.
- the stairs grass door and the left part are showing in white completly.
see attach of render photo and how its looks in sketchup before.
thanks
Is the plane inside a group/component??
No. As you can see the 2nd floor rooms are cut in sketchup but cant see them on v-ray only part of the door . About the whites colors i figure the problem. But these floors and the grass part i didnt.
