    Remove and purge hidden components.
    19 Posts 4 Posters 5.3k Views 4 Watching
      Consider this with 'grep'...
      Sketchup.active_model.definitions.each{|d|d.entities.grep(Sketchup;;ComponentInstance).each{|e|e.erase! if e.hidden?}}
      This will include only nested instances found inside definition's and then erase them, if they are hidden.
      • TNTDAVIDT
        TNTDAVID
        Thank you TIG and slbaumgartner ☀
        The TIG example works perfectly. 👍
        [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
        • TNTDAVIDT
          TNTDAVID
          **Is it possible to purge hidden components inside components with the IKEA definition only?
          This will avoid affecting all the file to target only the 3D models proposed by Click-Kitchen 2.
          For example:
          Method A selects all components with the IKEA definition.
          # Method A
          m=Sketchup.active_model;s=m.selection;m.definitions.each{|d|s.add d.instances if d.name=~/#{"IKEA"}/}
          Method B searches for hidden components inside the selection and deletes them.
          To write Method B, I need your help.
          Thank you
          David**
          • Dan RathbunD
            Dan Rathbun
            (1) Why are you putting quotes around IKEA ? (The regular expressions are themselves specially treated double quoted strings.)
            I'm not here much anymore.
            • Dan RathbunD
              Dan Rathbun
              (2) You are wasting time pushing objects into the selection set.
              This is not necessary in order to modify them.
              (3) Instances do not "own" any nested components. Definitions own nested objects.
              So you should be collecting a set of IKEA definitions, and then searching the definitions entities collection(s) (in that set,) for hidden objects.
              When a definition has a child object that is hidden, it will be hidden in ALL of the definition's instances.
              When you delete a hidden object from a definition, ALL of it's instances will have that child object deleted.
              • TNTDAVIDT
                TNTDAVID
                **I'm not sure I understand all of your logical reasoning Dan. 😕
                I want to delete hidden definitions and not instances.
                For example:
                Dynamic Cabinet consists of a Drawer and a Door.
                The Drawer is hidden by its "Hidden" attribute.
                The Gate is visible by its "Hidden" attribute.
                Both have instances "Handles" in "sub-component".
                The method must delete the "Drawer" definition because it is hidden.
                Thus, only the "Handles" instance of the drawer will be deleted without affecting the same instances of the door.
                Cordially
                David**
                • Dan RathbunD
                  Dan Rathbun
                  Definitions are not hidden in the model, because they do not exist in the model entities collection (only instances do.)
                  When a definition is "hidden", it does not appear in the Components Browser list, but still is a member of the model's DefinitionList collection.
                    As Dan says don't mess on with the selection-set...
                    IF you actually need to collect things for later use, consider using an array [] or a hash {}...
                    But that is NOT needed here...
                    How about this ?
                    Sketchup.active_model.definitions.each{|d|next unless d.name=~/IKEA/; d.entities.grep(Sketchup;;ComponentInstance).each{|e|e.erase! if e.hidden?}}
                    This deletes all nested entities within any definition named /IKEA/, if they are hidden...
                    • TNTDAVIDT
                      TNTDAVID
                      **Sorry Dan, I mixed brushes between definitions and instances ...
                      It's wonderful TIG, your code meets 100% to my needs. 👍
                      I want to be very careful with the selections or deletes, for this reason your example is perfect.
                      The code below removes all attributes of all dynamic components present in a SketchUp file.
                      m=Sketchup.active_model;m.start_operation("unDC");m.definitions.each{|d|d.attribute_dictionaries.delete("dynamic_attributes") if d.attribute_dictionaries and d.attribute_dictionaries["dynamic_attributes"];d.instances.each{|i|i.attribute_dictionaries.delete("dynamic_attributes") if i.attribute_dictionaries and i.attribute_dictionaries["dynamic_attributes"]}};m.commit_operation
                      How to adapt this code so that it only deletes the dynamic attributes of all nested entities in the named definitions / IKEA / ?
                      Thank you**
                        Adjust ...;m.definitions.each{|d|d.attribute_dictionaries...
                        to something like this:
                        ...;m.definitions.each{|d|**next unless d.name=~/IKEA/;**d.attribute_dictionaries...
                        To limit the action to /IKEA/ named definitions...
                        • TNTDAVIDT
                          TNTDAVID
                          Wonderful! Your example works TIG, for instances with IKEA definitions:**
                          m=Sketchup.active_model;m.start_operation("unDC");m.definitions.each{|d|next unless d.name=~/IKEA/; d.attribute_dictionaries.delete("dynamic_attributes") if d.attribute_dictionaries and d.attribute_dictionaries["dynamic_attributes"];d.instances.each{|i|i.attribute_dictionaries.delete("dynamic_attributes") if i.attribute_dictionaries and i.attribute_dictionaries["dynamic_attributes"]}};m.commit_operation
                          Is it possible to purge dynamic attributes of nested components in instances with IKEA definitions?
                          Thank you
                          • TNTDAVIDT
                            TNTDAVID
                            **Bonjour,
                            Votre solution TIG pour supprimer les composants masqués à l'intérieur des définition IKEA, fonctionne très bien! 😉
                            A l'intérieur de la définition IKEA, il y a beaucoup d'autres définitions qui ont des sous composants masqués.
                            Est-il possible de supprimer tous les composants masqués pour toutes les définitions présentes dans les meubles IKEA ?
                            L'idéal serait de na pas avoir à citer toutes les définitions existant dans les meubles IKEA.
                            Merci**
                            • TNTDAVIDT
                              TNTDAVID
                              **Little reminder:
                              It is possible to remove all hidden components of a SketchUp file, with this method:
                              It is possible to remove all hidden components with the name of a definition, with this method:
                              How to remove all hidden components and sub-components in a selection?
                              Thank you
                              David**
                              • TNTDAVIDT
                                TNTDAVID
                                **I finally found how to remove hidden sub-components from a selection:
                                mod = Sketchup.active_model
                                sel = mod.selection
                                sel.grep(Sketchup;;ComponentInstance).each{|s|;
                                s.definition.entities.grep(Sketchup;;ComponentInstance).each{|e|e.erase! if e.hidden?}}
                                The problem is that only the first level of nesting is removed by the method.
                                I will continue to search in esperente found the solution.
                                See you
                                David**
                                • TNTDAVIDT
                                  TNTDAVID
                                  **I can select all the definitions by their names and apply a cleaning of hidden components:
                                  def methode1 ### select components and sub-components with the name of the definitions.
                                      ["IKEA","DOOR","DRAWER","HANDLES"].each{|name|
                                      match = /#{name}/i
                                      s=m.selection;
                                      m.definitions.each{|d|s.add d.instances if d.name =~ match }}
                                  def methode2 ### remove hidden components in the selection
                                      Sketchup.active_model.selection.grep(Sketchup;;ComponentInstance).each{|s|
                                  def methode_end
                                      methode1
                                      methode2
                                  I'm progressing but this solution is not great. 😕
                                  Any help would be highly appreciated.**
                                  • TNTDAVIDT
                                    TNTDAVID
                                    **They always told me to be persistent and I thank all those who gave me this advice. 😄
                                    Here is the method to remove all hidden sub-components in a parent component:
                                    def supprimer_tous_les_sous_composants_selection(instance)
                                        children = instance.definition.entities.select { |e| e.respond_to?(;definition) }
                                        children.each { |c| supprimer_tous_les_sous_composants_selection(c);
                                        c.erase! if c.hidden?
                                        supprimer_tous_les_sous_composants_selection(Sketchup.active_model.selection.first)
                                    Here is the method to remove all the dynamic attributes of all the components present in a selection:
                                    def selectionner_tous_les_sous_composants_selection(instance)
                                        instance.model.selection.add(children)
                                        children.each { |c| selectionner_tous_les_sous_composants_selection(c);
                                    def supprimer_tous_les_attributs_dynamiques_selection
                                        sel = mod.selection
                                        sel.each{|s|s.definition.attribute_dictionaries.delete("dynamic_attributes");
                                      sel.grep(Sketchup;;ComponentInstance).each{|i|i.attribute_dictionaries.delete("dynamic_attributes")}}
                                    def desactiver_toutes_les_selections
                                        ent = mod.active_entities
                                        sel = mod.selection
                                        instances = sel.grep(Sketchup;;ComponentInstance)
                                        sel.clear
                                    selectionner_tous_les_sous_composants_selection(Sketchup.active_model.selection.first)
                                    You can test these methods directly with the ruby console, after selecting a dynamic component.
                                    You will notice that all hidden components and dynamic attributes will be removed, even if they are nested at multiple levels.
                                    Thank you to everyone who helped me. 😉
                                    See you
                                    David**
