    [Plugin] Texture Resizer (1.5.6) — updated 15.05.2013
    104 Posts 35 Posters 113.4k Views 35 Watching
    • OxerO
      Oxer
      The plugin (OS X version) work fine and very quick on Mac OSX & SU2013 but on SU2014 the processing is very long and sometimes SU crash.
      • brodieB
        brodie
        This doesn't seem to be working for me with 2015. Is it just me?
          Aerilius
          Sorry, I was away the last week. I tested it in SU 2015 and it seems to be still working.
          It requires ImageMagick to be installed (the plugin is just a UI and calculates the command for ImageMagick).
          • Do you have ImageMagick installed? If it was not, the plugin should prompt.
          • Is it possible the plugin does not find ImageMagick? Can you give me the results from the Ruby Console of:
          AE;;TextureResizer;;ImageMagick.installed?
          AE;;TextureResizer;;ImageMagick.class_variable_get(;@@install_location)
          Sketchup.read_default("ImageMagick","location")
          • F
            faust07
            Plugin works great in SU 2016 - a handy time and file size saver. Thanks!
            • P
              Pherim
              It doesn't work in SU2016 for me... I click apply and it just clears all parameters. There is nothing in the ruby console and I do have ImageMagick installed.
              • P
                Pherim
                Turns out I did not have the latest version installed because the extension warehouse still has 1.5.5. Now it just says "Processing" when I click "apply", but seems not to do anything if nothing is selected, whereas it creates resized versions of textures in a selection although it does not replaces the original ones but just adds a 0 to their names. It works in Sketchup 8, though. Could it be a conflict with another plugin?
                edit: It works on my laptop... so I guess I need to figure out the difference between these two installations to find out why it's not working on my PC.
                • P
                  Pherim
                  Me again... so far I found out that it appears not to be working when Make Fur by Tak2hata is also installed... however, only on my PC (Windows 7 64bit) in SU2016. With SU8 and on my laptop (also SU2016) it works! Any ideas?
                  • judedouchJ
                    judedouch
                    I've also got the same problem when Using the plugin , it just says "Processing" when I click "apply" and nothing more appens.
                    That problem occurs on my PC with SU 2014Pro and SU 2013Pro running on Windows XP Pro Sp3.
                    To Fix that problem on my PC I've done the following :
                    In ImageMagick.rb file located in ae_TextureResizer folder, I've made the following changes to Windows script host object ( adding in Run Method of WshShell a third argument "bWaitOnReturn=true") and add WScript suffix to CreateObject so lines 660, 661 and 664 have been revised as follow.
                    Line 660 : Add WScript. to CreateObject("WScript.Shell")] like that:
                    f.puts %[Set WshShell = WScript.CreateObject("WScript.Shell")]
                    Line 661 : Disable the code in this line like that:
                    #f.puts %[WshShell.Run """#{fbat}""", 0]
                    Line 664 : Enable the code in this line like that :
                    f.puts %[WshShell.Run """#{fbat}""", 0, true]
                    Previously, I've observed that the batch file named "commands.bat" create by ImageMagick.rb at C:\Documents and Settings\User\Local Settings\Tmp\skp_textureresizer\xyzabc folder is not lauched by the Visual Bacic file named "commands.vbs" create also by ImageMagic.rb file at line 657.
                    When I double click on the commands.bat file , the TextureResize plugin finalize the processing and then delete all components writen in C:\Documents and Settings\Jean\Local Settings\Tmp\skp_textureresizer\xyzabc folder.
                    • josephkim626J
                      josephkim626
                      It doesn't seem like this is in works with 2017 version.
                      Any plans for being updated?
                      • L
                        leetran72
                        On Extentions Store still version 1.5.5 (windows) 😠
                        • C
                          cloo
                          1. Extentions Store still has v.1.5.5, which does not work on SU2018
                          2. To work on SU2018, install extension from this post
                          3. You will need imagemagick. During installation, select "Install legacy tools" to obtain convert.exe, which is used by this extension.
                          • 6 / 6
