    Logic Function HELP!!
    Scheduled Pinned Locked Moved Dynamic Components
    3 Posts 2 Posters 6.8k Views 2 Watching
    • RichardR
      Richard
      I'm trying to do a logical function but with NO luck, and after help.
      Trying to get this!
      If a dimension (lenZ) of the component is greater than 300 then return 360,
      if it is less than 300 but greater than 270 then return 300,
      if it is less than 270 but greater than 240 then return 270,
      if it is less than 240 then return 240!!!!
      The old bloke just aint getting this stuff!
      BUILTBRAND.COM.AU
      • P
        pcmoor
        if using in the context of lenz attribute and assuming using cm, then value compare current("lenz")*2.54
        lenz = if(current("lenz")*2.54<=240,240,if(current("lenz")*2.54<=270,270,if(current("lenz")*2.54<=300,300,360)))
        if calculating a nearest_size attribute without forcing the lenz to snap to the result, then use
        size = if(lenz<=240,240,if(lenz<=270,270,if(lenz<=300,300,360)))
        using a logical.skp
        • RichardR
          Richard
          Sometimes, I think I'm smart, and then someone proves to me I'm not so!
          Sorry about the delayed response mate, I just got to try that and bang, works a treat!!!!!!!!
          You are a modern day superhero!!!!!!
          BUILTBRAND.COM.AU
