    3D Truss Models
    1.5k Posts 31 Posters 978.1k Views 30 Watching
    • medeekM Offline
      medeek
      I've had a bug report regarding the Gambrel Truss and Timber Truss features when using the plugin on MacOS. I am curious if any other Mac users are also experiencing issues when html or webdialog menus are being employed by the plugin.
      I've put more information on this developer's thread here:
      http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=68011
      If you are experiencing similar issues please contact me directly at nathan@medeek.com
      I would like to resolve this issue as it poses a serious problem for Mac users and will be a much larger problem as I slowly migrate to more Html based menus in the future.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I've started putting up all of the previous versions of the plugin here:
        Medeek Design Inc. - Medeek Truss Plugin Versions
        (design.medeek.com)
        design.medeek.com
          dpaul
          Recently I have not had a lot of feature requests so please fire away.
          Hello Nathaniel.
          Some thoughts for your consideration:
          The next big item on the list is the implementation of the straight skeleton algorithm and the ability to create any rafter roof shape, this is a big one.
          I agree, this is a very big one for us.
          The next big item which needs to be tackled is the ability to generate floor joists and trusses for any floor outline. the ability to cut holes in the floor assembly (stairwells, access doors
          Yes, essential for both. I would add (I may have mentioned it before) the need for a floor assembly to sit WITHIN a foundation wall so as to have the main floor level perhaps no more than 8" above grade. Clean walkouts to grade.
          Work on the Wall Plugin has begun in earnest
          Excellent. I have comments for you on the wall tool thread.
          The timber truss module. Just because I find it fascinating and would like to add it to the plugin doesn't mean it has any real world utility, I've learned that through experience.
          Your comment and implied question on 'world utility' brings me to the following observations:
          I do not believe many of the truss items you are developing, such as plates, bolts, gussets, etc.---all of them very specific engineering components---are required by your present user base. In fact, we cannot use them. It is almost as if you are writing code for structural engineers, when in fact, P.Eng's have their own software to overlay their drawings over our working drawings. They would not use your plugin for what they need to produce for us designers (in the broadest sense) as they have their own.
          We need your truss plugin, along with the floor/foundation and wall tool to help us speed up the building design process, NOT produce stamped structural drawings from them ourselves for local jurisdictional approval. Simply put, even if we wanted to, we are not allowed to produce engineering drawings with your plugins. Hence the P.Eng.
          As such, if it might be possible to move away from all the structural components (dealt with, as I say, by others and their software) and put the focus on speeding up the design process itself for walls, floors, foundations, and roofs to say, the 80% level (leaving structural to others) that would give us the speed--the essential utility----we are looking for.
          I will bring it up on the other thread, but SONDER's drawings are a very good example of the direction working drawings are taking: at 1/4"-1-0" we need very little information in any given cross-section (note the grey area in his attached section). It is in the detail drawings (Nick's are the best I have seen in a long time: superbly expository) where information for a builder can be placed. They are not needed in a cross-section unless it is at a far larger scale, and even then they can be produced as separate files and brought into Layout for final output.
          Provide us the ability to speed up our building design process with your plugins (soon to be one, I trust). If so, it will, as I have said before, become a game-changer.
          As always, these plugins have my vital interest and I offer you my sincerest best wishes for continued success. It is evident to me you are doing premium work.
          • medeekM Offline
            medeek
            @dpaul
            Thank-you for your excellent feedback and comments. I think this is probably some of the best advice I've have had in a long while with regards to the general direction of my "architectural" plugins.
            With regards to Item #2, please send me some details on your floor assembly that sits within the foundation. I need to understand how this construction comes together and works.
            Realize that the genesis of the Truss Plugin actually came from my Truss Calculator which is an engineering analysis tool and not a design tool. I kind of came into the plugin world with an engineering mindset but have slowly evolved into a design tool developer as the client base has pushed me progressively in that direction. In an effort to make the plugins more useful I have tried to keep the big picture in mind but sometimes I get sidetracked and fall back into my engineering ways.
            Ultimately, I have plans to develop a plugin specifically for residential structural engineers, and it will be a game changer for engineers like myself, especially if I can fully automate the load takedown, analysis and report generation.
            I realize that some of the details are probably not needed in the generation of a roof or model but at the same time I enjoy making fairly realistic models (I'm not into cartons). Hence, the truss plugin has been enabled with details such as plates, rakeboards, sub-fascia, gypsum, ridge cap etc... I have been considering adding in some more advanced options such as soffit, fascia, barge board and soffit boxes to better finish off the roof. I will be requesting more feedback on these items moving forward to make sure that they are something needed or wanted.
            Speeding up the design process is really what it is all about, I get that. If the designer can create an entire roof in a matter of seconds versus spending hours manually drawing all of the various elements this is certainly worth something. However, the plugin needs to be able to take care of all the details without bogging down the designer, if the details are to be included. The truss plugin currently can successfully do this for a simple rectangular roof or floor outline (hip or gable) but as soon as you get into anything more complicated it again becomes a manual process and the details become more a hinderance than a help
            With the foundation plugin I have attempted to address the non-rectangular footprint with some success. However, the final step is to provide a preview screen which will allow one to accurately place and preview potentially multiple internal bearing points/footings.
            Items #1 and #2 are big and would push the Truss Plugin to the next level.
            design.medeek.com
              dpaul
              Hello Nathaniel
              I appreciate being able to provide you feedback as per your invitation to do so. It also helps me think through what I could most use for my house modelling.
              Please see the attached sketches from Rob Thallon's book GRAPHIC GUIDE TO FRAME CONSTRUCTION (it has been an invaluable reference to me since I bought it quite a few years ago now). The sections he drew show clearly what I have referred to as 'floor assembly within the foundation walls'.
              Never a problem. I value the context of your coding journey.
              I did not know this, but I fully agree: it will be a game-changer, not only for engineers but for firming up the communication and synchronicity of drawings with SU as the platform for both engineers and designers. Your direction here is a very good thing, I am convinced.
              We want all of these 'menu items'. They fully support and speed up detailed modelling.
              Now, this can be an ongoing--and compelling---conversation with us, your user base, as you sort out how to go about coding for modelling complexity. This is an attractive problem to solve, I can only imagine.
              Very cool indeed......πŸ˜„
              A tip o' the hat.
              • medeekM Offline
                medeek
                Version 1.9.9 - 09.12.2017
                • Added a hip & ridge option for gable rafter roofs.
                • Fixed some miscellaneous bugs with rafter roof modules.
                There were some really annoying issues with the rafter roof module that needed to be addressed. I still have more work in this regard since I need to go through all of the other rafter roof modules (glulam beam, dual glulam beam etc...) and clean a few things up but I made a fairly good dint in it this evening.
                At some point I would like to also add roof returns to the gable rafter roofs, this should not be too big of an issue. Another thing to add to the todo list is partial roofs where a rafter roof butts up against a larger wall and/or roof.
                The list never ends, but then I never quit, I'll probably still be working on this thing 20 years from now when I'm 65.
                design.medeek.com
                • jujuJ Offline
                  juju
                  Thanks for putting in the effort!
                  • medeekM Offline
                    medeek
                    @dpaul
                    Framing the floor joists flush with the sill plate seems to be particularly popular in Oregon, I've never seen this done before until I did some structural jobs in that area.
                    I've seen a number of configurations and details. Some actually use pockets in the stemwall, others use the ledger method as shown in the images above. I've also seen where the ledger is below the joists which then directly bear on the ledger. I will see what I can do in this regard.
                    design.medeek.com
                    • pbacotP Offline
                      @medeek said:
                      @dpaul
                      Popular in California too. Good connection of floor diaphram to foundation. Used where the grade outside may be higher than the crawl space, or a waterproof terrace is adjacent (in which case the curb may also be raised and the sheathing is NOT over the mudsill). The disadvantage is in running power and plumbing up through the wall.
                      • medeekM Offline
                        medeek
                        Two issues with this system:
                        1. As noted above getting the utilities into the wall from the crawlspace presents a challenge, especially plumbing.
                        2. Insulating for cold weather environments is also difficult. Where the corner of the interior space is almost in direct contact with the stemwall creates a thermal bridge.
                        The major advantage of this system is less sheathing needed for exterior walls since you don't have to add in the height of the rim joist.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          I've been thinking about multi-level roofs and how to deal with them.
                          http://design.medeek.com/resources/images/truss_su267_800.jpg
                          Currently I don't see a good way to automate truss roofs, I think there will be some manual intervention required.
                          For rafter roofs though I think I can fully automate the process.
                          View model here:
                          3D Warehouse
                          (3dwarehouse.sketchup.com)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            As I previously mentioned I am slowing working on making all previous version of the plugin available here:
                            (design.medeek.com)
                            Each new version adds improvements and fixes. Probably at some point once this plugin has fully matured then I might see a good reason to install a previous version, but hopefully I never get to that point where the plugin becomes bloatware.
                            I suppose the only reason to install a previous version is if you have an expired license and do not wish to upgrade, I can respect that, especially if you only use the plugin on a infrequent basis.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Starting to work on the straight skeleton algorithm today, complex roofs have got my attention.
                              The model below has a saddle point and this lends itself to some rather complex framing:
                              http://design.medeek.com/resources/images/truss_su268_800.jpg
                              Even with the roof primitives and trim tool, which helped out tremendously, it still took me almost an hour to fully generate the roof framing.
                              http://design.medeek.com/resources/images/truss_su269_800.jpg
                              The goal is to turn hours into seconds.
                              http://design.medeek.com/resources/images/truss_su270_800.jpg
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                If you really want a headache try and truss out this same roof outline:
                                3D Warehouse
                                After about 45 minutes I've given up, not because it can't be done but because the amount of custom truss profiles and manual editing required far exceeds my patience and determination.
                                On a different note it looks like the extension warehouse is down so I am unable to sign any new revisions to the extensions, I guess 1.9.9b will have to wait.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Needing a break from the rigors of the straight skeleton code I realized that I have still not implemented the octagon hip roof yet. On a related note the circular roof could also use my attention:
                                  http://design.medeek.com/resources/images/truss_su271_800.jpg
                                  View model here:
                                  3D Warehouse
                                  The number of rafters can be given by this equation N = 8 + 8n where n = 0,1,2,3,4 etc...
                                  In this model n = 3
                                  People do actually build these things:
                                  http://www.quittintime.com/attachments/3705-Dscn4931.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    A turret roof:
                                    http://design.medeek.com/resources/images/truss_su272_800.jpg
                                    View model here:
                                    3D Warehouse
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Winter is coming...
                                      http://design.medeek.com/resources/images/truss_su273_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        View model here:
                                        3D Warehouse
                                        Using the hip rafter roof as a template it won't be too hard to add the octagon and circular roof, two more checkboxes to fill. I do admit that sometimes I like the low hanging fruit, but it is really the challenging stuff that piques my interest and drives me.
                                        I've had a bit of a cold all night, tempted to call in sick and spend the rest of the day coding but my wife would probably kill me if I did.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Working on adding in the inset floor joists per the details given by dpaul:
                                          Parameters are the following:
                                          1.) Stemwall Thickness (inset amount)
                                          2.) Ledger Option: Yes or No
                                          3.) Ledger Height
                                          4.) Ledger Width
                                          5.) Hanger Option: Yes or No
                                          I'm still waffling on what to do if the hanger option is "yes". I was considering having the option of selecting one of the many Simpson-Strongtie hangers from a long list of hangers. However, no models exist for the bulk of these hangers and I don't have the time or data to try and model a bunch of them. Item 5 may not be feasible.
                                          I also have a question on the ledger board option:
                                          http://design.medeek.com/resources/images/truss_su274_800.jpg
                                          As you can see in the image the 2x12 PT dimensional lumber ledger is smaller in height (11.25") than the 11-7/8" TJI. In this case would the ledger be run flush to the bottom of the TJI or is this not a concern? I was thinking that one would probably call out an LVL or LSL ledger with felt backing between the ledger and the concrete so that the ledger matches the height of the I-joist. Additional information when the floor joists are I-joists or EWP would be helpful here.
                                          View model here:
                                          3D Warehouse
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Someone suggested that I try out Patreon rather than Kickstarter:
                                            Redirecting...
                                            (www.patreon.com)
                                            design.medeek.com
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 75
                                            • 76
                                            • 50 / 76
