    Excluding scenes from animation
    11 Posts 4 Posters 5.2k Views 4 Watching
      Skastafari
      I am looking for a method to exclude pages from my animation similar to how the "Include in animation" checkbox works from within Sketchup's scene editor. I am generating multiple scenes that cannot be included in my final render, and find the extra step of checking each of those mixed in scenes to exclude them quite tedious. I am having trouble finding an example of how to achieve this in the API documentation. I noticed the parenthesis around scene names in animations and thought perhaps that was the indicator of an excluded scene, and it would be simply...
      model = Sketchup.active_model view = model.active_view pages = model.pages #(define operation here e.g. view.camera.perspective = false etc.) status = pages.add "(excluded scene)"
      However elegant this would seem, unfortunately it does not work. So I am guessing there is some other method to exclude scenes from the animation.
      I had found a thread from Dan Rathbun somewhere dating a couple years back discussing a need for this, but I can't seem to find what the outcome was. If anyone knows, please advise.
        A page's page.name and its page.label are NOT the same IF a scene tab is set to be excluded from a scene-animation - because then parentheses are added round the name when forming the label string.
        http://ruby.sketchup.com/Sketchup/Page.html#name-instance_method
        http://ruby.sketchup.com/Sketchup/Page.html#label-instance_method
        This is a simple way of ensuring that only 'included' scene-tabs' pages get processed...
        animated_pages = Sketchup.active_model.pages.find_all{|page| page.name == page.label }
        • sdmitchS
          sdmitch
          Tig, is there a way to access the "Include in animation" and "Play" from a script?
          http://sdmitch.blogspot.com/
            My snippet does this - making 'animated_pages' subset ??
            Since a page's page.name is the same as its page.label when it is included in an animation....
            I don't think you can actually change the 'label' in the API ?
            As far as I know you can't run the animation tool via the API, but of course your can simply step through the collected pages [scene tabs] in turn - using the 'animated_pages' subset, which I already explained how to assemble.
            The transitions etc between pages is pre/re-set under various option settings ?
            The page.delay time transition_time etc etc...
            • sdmitchS
              sdmitch
              If i select a scene in a model, the transition time is applied but, if I select that same scene from a script, there is no transition and no delay unless I use sleep(). Entering the same script statement in the Ruby Console works just like selecting the scene in the model. The closest I have come is setting the view camera to the page.camera and refreshing the view but this bypasses the transition.
                Skastafari
                Okay, I just learned a lot. So I gather that in order for a page to be excluded from the animation it would need parenthesis to wrap the label string, but when you create a page from the ruby API by default the name IS the label string so that explains why my idea did not work and also why when I uncheck Include in animation the tab name now has 2 sets of parenthesis. If it is true that we can not change the label from the API, then there really is no way I can achieve the function I need as far as I can tell.
                I guess that is why Dan had put in this request back in the day:
                https://forums.sketchup.com/t/ruby-sketchup-page-use-in-animation-use-in-animation/11020
                Thank you for your script and insights Tig. It was helpful to me. I do have a better understanding what is going on now.
                  Skastafari
                  I just found this...
                  Handling "Include in animation" flag in Scenes
                  I am wondering if there is a way to handle the “Include in animation” flag from the API. I can’t see any related method in Sketchup::Page, so I guess it is not possible at all. Any hint? It would be useful to define whe…
                  SketchUp Community (forums.sketchup.com)
                  I guess this is as close as I am going to get to the status of Dan's request.
                  • sdmitchS
                    sdmitch
                    Using the page.name==page.label would certainly work. I'm still trying to solve the transition problem. I found this in the API but I have yet to get it to be recognized. Perhaps it has been removed or never implemented.
                    • Dan RathbunD
                      Dan Rathbun
                      When you manually change scenes (and the model does not have specific transition and/or delay properties assigned to individual page objects,) then the model's global animation transition and delay settings are used.
                      Global settings are via:
                      Window > Model Info > Animation
                      Global transition and delay is accessible via the model's options provider objects.
                      manager = model.options
                      popts = Sketchup.active_model.options["PageOptions"]
                      popts.each {|o| puts o }
                      #=> ShowTransition
                      #=> TransitionTime
                      sopts = Sketchup.active_model.options["SlideshowOptions"]
                      sopts.each {|o| puts o }
                      #=> LoopSlideshow
                      #=> SlideTime
                      A per scene page settings interface is not yet implemented, but I think I myself and others have requested it as a PRO feature request. (I believe it should be a Pro only feature myself.)
                      You can easily write a script to set per page transition and delay.
                      I also think some of the better animation extensions have UI interface to set per scene transition and delay. (I think Smustard's does.)
                      I'm not here much anymore.
                      • Dan RathbunD
                        Dan Rathbun
                        @sdmitch said:
                        I found this ( view#camera=) in the API but I have yet to get it to be recognized.
                        See:
                        (SketchUp Developer forum): Setter #view.camera= Testing with Second Transition Time Argument
                        The API docs are a bit confusing.
                        The view#camera= method is an overloaded method, which can be used two ways:
                        1. with a single Sketchup::Camera object argument
                        2. with a single Array argument of: [ Sketchup::Camera, Float ]
                          (The Float being the transition time.)
                        If you attempt to pass two arguments, of Sketchup::Camera and Float, the API ignores the second (time) argument and you get behavior #1. (Ie, a silent failure from what you'd expect.)
                        • Dan RathbunD
                          Dan Rathbun
                          FYI,... Finally, ... the API has been updated for version 2018 and higher ...
                          ... both a query method and a setter method have been added to the Sketchup::Page class.
                          • Sketchup::Page.include_in_animation=
                          • Sketchup::Page.include_in_animation?
