    Why don't guides seem to stick to faces?
    2 Posts 2 Posters 712 Views 2 Watching
    • O
      olso5345
      Hi All,
      I created a face, and created guides 1" in from each edge. Where the guides intersect near the four corners, I created 1/2" circles. I want to extrude each of those circles out 1/8", but only some of those circles have adhered to the face. So it seems the guides I created have not inferenced the face. As a work around, I use actual lines as a proxy for guides, then make my circles centered on the line intersections, then erase the lines, then extrude the circles. I wish this would work more gracefully using just the guides. Any way I can force the guides to inference the faces so I use the guides for reliable circle placement? Many thanks!
        It's better if you post an image and more an skp file (save as V6)! πŸ€“
        Else I don't see why you have this problem! πŸ˜„
        https://s6.postimg.org/jsc4dqpe9/GIF_circle.gif
        Guides are drawn following a previous one as inference line!
        https://s6.postimg.org/euyjsmnf5/GIF_circle1.gif
        Circle is drawn with taking the orientation of the face by Shift!
        https://s6.postimg.org/7t57k6975/GIF_circle3.gif
        First guide is drawn by a move and come back! πŸ˜‰
        (move & back can be external or internal as following)
        https://s6.postimg.org/bqsh9kw0h/GIF_circle4.gif
