    Ruby not returning correct dimensions
    4 Posts 2 Posters 1.3k Views 2 Watching
    • F Offline
      Frankn
      Sorry in advance for what may be a really noob question and I know I've seen this before but been away from scripting for a while and can't remember and can't find the solution by searching...
      Basically if I have 3 components in my model each being 1/2" thick when I retrieve the components dimensions in ruby, 2 of them return 0.5 and one returns 0.4999999999999716. Why? and how do my fix that? I did try adding .to_l in my code but that didn't help.
      • TIGT Online
        0.4999999999999716" IS for all intents and purposes 0.5"
        All computing code will have some approximation built in to it.
        SketchUp's is 1/1000"
        That's 0.001"
        So quite clearly 0.4999999999999716" is equivalent to 0.5" for all practical purposes.
        If you need to output the value and you are unhappy with the 'nearness' there are code method to return a user expected 'dim value'...
        • F Offline
          Frankn
          Thanks for the reply and clarification Tig!
          The issue I'm having is that I'm using group_by to group by thickness but since the values don't match group_by doesn't work. So knowing what you just explained I'm using 0.4999999999999716.round(6) and that seems to do the trick. I use (6) because some values in inches have six digits after the .
          If there's another way fix this issue please let me know.
          • TIGT Online
            You have found your own solution.
            πŸ˜‰
