    1.5k Posts 471 Posters 3.3m Views 470 Watching
    • I Offline
      interconnect
      That worked. Would never of thought to do that. Thanks!
      • I Offline
        interconnect
        How do I round or bevel the inside edge of a circle? Whenever I do it my model gets filled somehow. I'm sure I must be missing something.
        • fredo6F Offline
          NEW RELEASE: RoundCorner v3.2b - 24 Jun 17
          RoundCorner 3.2b is a maintenance release. It fixes a bug when selecting edges interactively in certain situations (usually with corners of 4 edges and more).
          Home Page of RoundCorner for information and Download.
          Main post of this thread.
            secretling0617
            ιžεΈΈζ„Ÿθ¬εˆ†δΊ«~~
              tramspotters
              Great plugin, but unfortunately on a Macbook with Retina display the toolbar is really tiny. Is it possible to consider this in the next update?
                barakuda
                RoundCorner is great tool. I used it in SU8 to perform small modifications of terrain (squares 5mx5m).
                I have tested versions 2.3 and 3.2b (current). To compare.
                With v2.3 I have found problem when I try to select edges and junctions idividualy. The arro color often changes from blue or from orange to red. This is not what I want. Because the SU8 reacts slowly, often happened to me often that the selection which I did was removed because the red arrow was there. I mean, it was not visible, but the SU thinks like it is there because the SU runs slowly when it must work with a lot of entities. Hence for this selection I found the red arrow completely useless. I please, you either remove it from your program or give option to disable the function of complete selection of edges using red arrow. For me this is discomfort and frustrationg when I can not disable it.
                In v3.2b. The selection of individual edges is more easy than in v2.3. Less work. But the SU8 have crashed after a minute of work. So I have to uninstall the 3.2b and I hope in the next version you will fix the problem.
                Thank you for your tool
                  barakuda
                  Once again testing 3.2b
                  and this error occured:
                  Ruby Error - Round Corner - 03-Jul-17 13_10_04.txt
                  Date: 03-Jul-17 13:10:04
                  An error occurred in Round Corner
                  Error
                  Cannot convert argument to Sketchup::Point3d
                  (eval): 1878 -- add_edges
                  (eval): 1878 -- robot_protected
                  (eval): 1874 -- each
                  (eval): 1874 -- robot_protected
                  (eval): 1854 -- robot
                  (eval): 1848 -- robot_top_execute
                  (eval): 332 -- call
                  (eval): 332 -- step_geometry
                  (eval): 293 -- yield?
                  (eval): 605 -- call
                  Please contact me if you want to solve this bug.
                  • fredo6F Offline
                    It would help if you post the model, because the bug is probably related to the model. Again, RoundCorner cannot handle all cases, especially in complex models.
                    Does it happen with a simple cube?
                    Regarding the Red arrow, which is to pick the edges of a face, I don't understand your problem.
                    If Sketchup is so slow, then you have a more general problem. In SU8, I would suggest you have a look at the settings in Window > Preferences > OpenGL and try to change the "Capabilities". This may be the source of bad performance.
                    • fredo6F Offline
                      I think I have to do it, as I don't expect this will be fixed by sketchup any time soon.
                      For the palette, I can probably grow it.
                      Could you tell me if the red and green lines (displayed when you select edges) needs also to be thicker?
                      There is now a discussion on the subject.
                        ScetcheeDave
                        Hi Fredo, great Extn. Im very beginner. Im getting a failure (me?). This object is 22mm diameter - hopefully the images speak clearer than I can. Im trying to round off edges highlighted in image below but to do so results in fill in or some other failure see other 😞 .jpg. Any ideas?
                        You can see in the image with green ticks it worked on a couple of edges. It works if I only select 1 or a couple of edges.
                        http://i.imgur.com/TInPQr5.jpg
                        http://i.imgur.com/xRMKbnL.jpg
                        • BoxB Offline
                          Click on your sad face and hit delete on your keyboard.
                          http://i.imgur.com/NQUcLdP.gif
                            ScetcheeDave
                            you just coined a new phrase πŸ˜‰ Thanks works great.
                              ScetcheeDave
                              Actually... it worked great but also deleted the sides in the centre piece. I can and have fixed it easy enough but thought I would see if it was caused by something else i can do better.
                              http://i.imgur.com/ihtWjT2.jpg
                              • BoxB Offline
                                You are running into the Tiny Faces issue. SU has problems forming faces when the edges segments get below 1mm. Scale your geometry up to do complex edits, then scale down again.
                                Or use the Dave Method of scaling a component instance up to edit then delete the large one and the small one will retain the edits.
                                http://i.imgur.com/3wF3ekd.gif
                                  barakuda
                                  Originally I wanted to post PM to you but I could not because the PM function is disabled.
                                  I also waited if author of Selection Manager will reply and repair his stuff to make it working. I needed to save the selection to show you which edges I am planing to work. Without the selection this is useless to write to you. I have no way how to show what I am trying to do exactly. I wanted to use the Round Corners to round corners of the mesh bellow.
                                  Now I tried to generate edge 1m offet and 1 side then 2 sides. All works fine.
                                  Now I have added more edges with 3 sides and everything works fine. I obtained information when the offest 1.25 was too much and would create overlaps.
                                  On the mesh I did succesfully 1st floor/elevation. Then I move up +4m few faces and I try once more to round the edges. Some gaps has been created on the second floor. I add the model.
                                  During this test I have not found serious problems.
                                  Previous job what I did was with file which was much more bigger. Same grid 5m spacing 1km x 1km (same texture) worked very slow. The problem was that when I wanted to select the edges manually red arrow suddenly appeared and I clicked it by incident. Because of it I suggest to have possibility - option do turn of some arrows which I do not plan to use. This would be solution for performance problem. With small objects like this there is no serious performance problem so it works nice.
                                  round corners mesh.skp
                                    thaiscardoso
                                    Actually, I installed a last version of libfredo. Ok, anyway. But when try to install RoundCorner v3.2b, the sketchup say to me: "You must install libfredo6 to rum RoundCorner.
                                    Someone can help me about it? Version Sketchup 2015.
                                    LibFredo already installed:
                                    http://i64.tinypic.com/nv85ch.png
                                    Message error:
                                    http://i63.tinypic.com/ajscap.png
                                      babliadrian
                                      Same error here! :S
                                      Please help!
                                      • fredo6F Offline
                                        @babliadrian
                                        This may be related to special characters in your username.
                                        Could you replace the attached file in the Sketchup Plugin Directory, and advise if this solves the problem.
                                        Fredo6_RoundCorner.rb
                                        Thank you
                                          babliadrian
                                          The tool is working now! πŸ˜„
                                          So, once again...
                                          What was the problem? And what have you done?
                                          Thank you!
                                          • fredo6F Offline
                                            So, once again...
                                            Thank you!
                                            This is related to non-ascii characters in your username under Windows. For whatever reason, even with SU2017, this seems to create some problem when checking folders and files for existence.
                                            • 73
                                            • 74
                                            • 2 / 74
