    Knowing the ComponentInstance a DimensionLinear is attached
    5 Posts 3 Posters 1.6k Views 3 Watching
    • I Offline
      ittayd
      I have a dimension attached to a component instance (it moves with it, changes when it is stretched, etc.). Using the API, dim.start[1].parent returns a ComponentDefinition. This of course doesn't tell me which instance it is attached to. Is there a way of knowing? Or is it a bug?
      (A brute force method is to go over every instance, iterate over all its vertices and compare with the one of the dimension. I'm looking for something more elegant, and that will work when attaching to an edge etc.)
      • Dan RathbunD Offline
        Dan Rathbun
        Yes.
        dim.start[0]
        Test it. If it is nil the dimension is unassociated.
        dim.start[0].nil?
        or simply in Ruby:
        ` inst_start = dim.start[0]
        if inst_start
        use it
        else
        assume it is nil as nil evals as FALSE in Ruby
        end`
        You can also use Ruby's multiple assignment:
        ent, point = dim.start
        Ref: http://ruby-doc.org/core-2.0.0/doc/syntax/assignment_rdoc.html
        @ittayd said:
        Or is it a bug?
        Sounds like a brain bug. ๐Ÿ˜‰ (Reference to "Starship Troopers II".)
        As the API doc is quite clear that the first member of the returned array is supposed to be a reference to the entity.
        I'm not here much anymore.
        • I Offline
          ittayd
          dim.start[0] will return a Vertex or Edge. How do I know the ComponentInstance dim.start[0] is part of? As I wrote dim.start[0].parent returns a ComponentDefinition.
            Dan Rathbun
            FYI, it's been shown By ittayd that this is bugged. Thomas Thomassen has filed the bug internally.
            The method is supposed (according to the API docs) to return the instance in favor of any primitive (vertex, edge, etc.)
            See:
            https://forums.sketchup.com/t/how-can-i-tell-to-which-instance-a-dimension-is-attached/47309
            • TIGT Online
              Until it's fixed how about a clunky and convoluted workaround ?
              If the pa=dim.start[0].parent is a component-definition then you need to see if there is pa.instances[1] if not then the one instance is the answer.
              If there are more than one instance you need to iterate those, and assemble a list of their transformation.origin positions [ensuring the transformation steps back to match the dim's parent's and of course takes into account any instance scaling etc...] - let's call that 'pvs'.
              The pt=dim.start[0] gives you a point inside the definition.
              You have ps=dim.start[1] as the point of the dim in 3d space.
              Transform the 'pvs' inversely and compare that point with ps, if they match then you could have a hit.
              Of course two or more instances where some are rotated or flipped so that vertex is coincident in 3d returns two or more 'hit' points, so it'd not be possible to determine the attachment that way...
              So, it's better if it worked like it should !!!
