    How to implement entity selection "wizard"
    5 Posts 4 Posters 1.3k Views 4 Watching
    • I Offline
      ittayd
      In Sketchup most of the tools contain a sort of "wizard" where the status line tells you what to pick and then when you pick it, what to pick next, etc. How can I do this in an extension?
      • sdmitchS Offline
        sdmitch
        The set_status_text method is used to set the text appearing on the status bar within the drawing window.
        If no arguments are passed, the status bar content is cleared. Valid positions are:
        SB_PROMPT - the text will appear at the left-side of the status bar
        SB_VCB_LABEL - the text will appear in place of the VCB label
        SB_VCB_VALUE - the text will appear in the VCB
        Sketchup.set_status_text "This is a Test", SB_VCB_VALUE
        http://sdmitch.blogspot.com/
        • I Offline
          ittayd
          Thanks. And how do I pick elements one by one? Do I need to listen to mouse clicks or is there something that takes care of the flow for me?
            You need to set up your Extensions as a 'Tool'.
            http://ruby.sketchup.com/Sketchup/Tool.html
            Clear the selection as you initialize.
            On a mouse-click you use a pick-helper.
            That filters what you have clicked on - so you can have various results.
            You then filter that further by limiting what chosen by some other factor[s] like: context, already-selected, material, layer, name, attribute etc.
            If you have a valid object add it to the selection.
            Repeat until the user exits - e.g. double-click or <enter> press - then go onto the next step in your tool...
            • Dan RathbunD Offline
              Dan Rathbun
              ... and new for SketchUp vers 2016 and higher is a rectangular window picking method:
              http://ruby.sketchup.com/Sketchup/PickHelper.html#window_pick-instance_method
              You should download the SketchUp Team's Examples extension to see how Tools are written.
              http://extensions.sketchup.com/en/content/example-ruby-scripts
              I'm not here much anymore.
