    Help trimming two intersecting objects
    3 Posts 2 Posters 436 Views 2 Watching
    • I Offline
      Involute
      I'd like to trim off the portion of this tube that's protruding into the funnel so that the remaining tube is conformal with the funnel's surface at the entry point. I've tried using various solid commands like Split but the results are wonky and not 3D-printable (which I need). Thanks for tips. .skp attached.
      Funnel 6 - before.skp
      • pbacotP Offline
        I made a solid component with "outer shell" command.
        A couple of things. You need to reverse the face of the surface inside the pipe. After performing outer shell it's easy to remove the pipe inside the funnel and the faces blocking the pipe. Then you also need to erase the extra surface of the pipe as it passes through the funnel wall. You need to hide a surface so you can get to it. After unhiding the surface I use TT CleanUp to get rid of uneeded edges, but this removes a couple faces in the funnel outflow, but that is easy to fix.
        It seems to me outer shell does not completely work right or the inner faces wouldn't be there.
        • I Offline
          Involute
          That did it. The STL's been approved by Shapeways. Thanks!
