    Boolean Subtraction or ???
    12 Posts 7 Posters 3.1k Views 7 Watching
    • JQLJ
      JQL
      Edge tool 2 split faces tool can also give you some clues.
      www.casca.pt
      Visit us on facebook!
      • jolranJ
        jolran
        You might want to check out 2DBoolean by Joel G. Just the thing for this operation.
        I thought so to at a first glance. But then I looked closer at the Picture and it does look like the metal-net is inside the volume meaning a 3D boolean is needed. 2D-boolean plugin only have algorithms for working with planar (face) intersections.
        I don't think you have any other alternatives then winding up your own intersection formula using Groups and sorting out geometry if you are not going to use PRO version boolean.
        • G
          Garry K
          One option is to detect whether the user has Pro or Make. If Make - then skip the rebar. If Pro then use the available boolean functions.
          • sdmitchS
            sdmitch
            @medeek said:
            Currently the rebar or mesh is created so that it extends to the full extent of the bounding box of the slab. I would like to use the boolean subtraction that is built into SketchUp to trim the reinforcement so that it is properly contained within the slab.
            What should the distance be from the end of the rebar to edge of the slab?
            http://sdmitch.blogspot.com/
            • P
              pcmoor
              50mm or 2 inch
              • G
                Garry K
                I have sent you a PM with a code snippet.
                select the face of the slab and run the code and you will have construction points offset by 50 mm.
                Adjust the code to fit your needs.
                • sdmitchS
                  sdmitch
                  Not that difficult.
                  • medeekM
                    medeek
                    @Sdmitch: I'm testing your Subtract tool you sent me a while back and it almost works! However when the subtraction breaks the solid group into more than one physical solid then the process seems to break down slightly.
                    In a nutshell I need to be able to do this sort of thing:
                    https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=82746e2c-7867-4de3-8b47-56364b2a6593
                    Where I am subtracting the odd shaped polygonic solid from the cylinder.
                    This last week has been challenging working on the polygon tool for the foundation plugin, I've made some real progress, thanks in a large degree to the continual help and encouragement from Sdmitch, Garry K, TIG and Facer. I'll readily admit my actual SketchUp programming skills are very weak whereas my ideas are very big, it sometimes amazes me I've gotten as far as I have with these two plugins. The fact that I am able to lean on others for some help on occasion has made all the difference.
                    Nathaniel P. Wilkerson PE
                    Medeek Engineering Inc
                    design.medeek.com
                    • sdmitchS
                      sdmitch
                      Yes, I see where it would since it the opposite of what you are trying to accomplish with the slab and rebars. I will PM you the interactive tool version of the plugin I demonstrated in my previous post.
                      • medeekM
                        medeek
                        I'm still digging through the code you sent me. It may take a week but I will attempt to figure out how this actually works. Its amazing how much you are able to compress into such a small body of code.
                        design.medeek.com
                        With your input, this post could be even better šŸ’—
