    Boolean Subtraction or ???
    12 Posts 7 Posters 3.0k Views 7 Watching
    • medeekM
      medeek
      I am working on the foundation plugin, in particular slabs and slab on grade foundations. I am creating a tool that allows the user to generate a polygon shaped slab, see below:
      http://design.medeek.com/resources/images/foundation_su33_800.jpg
      Currently the rebar or mesh is created so that it extends to the full extent of the bounding box of the slab. I would like to use the boolean subtraction that is built into SketchUp to trim the reinforcement so that it is properly contained within the slab however this feature is only available in the Pro version.
      The intersect_with method is probably the next best thing but it seems like it will be quite a bit more complicated to subtract out the rebar that is external to the slab, especially where the rebar is cut in multiple locations.
      I am exploring any and all options.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • bazB
        baz
        You might want to check out 2DBoolean by Joel G. Just the thing for this operation.
        • JQLJ
          JQL
          Edge tool 2 split faces tool can also give you some clues.
          www.casca.pt
          Visit us on facebook!
          • jolranJ
            jolran
            I thought so to at a first glance. But then I looked closer at the Picture and it does look like the metal-net is inside the volume meaning a 3D boolean is needed. 2D-boolean plugin only have algorithms for working with planar (face) intersections.
            I don't think you have any other alternatives then winding up your own intersection formula using Groups and sorting out geometry if you are not going to use PRO version boolean.
            • G
              Garry K
              One option is to detect whether the user has Pro or Make. If Make - then skip the rebar. If Pro then use the available boolean functions.
              • sdmitchS
                sdmitch
                @medeek said:
                Currently the rebar or mesh is created so that it extends to the full extent of the bounding box of the slab. I would like to use the boolean subtraction that is built into SketchUp to trim the reinforcement so that it is properly contained within the slab.
                What should the distance be from the end of the rebar to edge of the slab?
                http://sdmitch.blogspot.com/
                • P
                  pcmoor
                  50mm or 2 inch
                  • G
                    Garry K
                    I have sent you a PM with a code snippet.
                    select the face of the slab and run the code and you will have construction points offset by 50 mm.
                    Adjust the code to fit your needs.
                    • sdmitchS
                      sdmitch
                      Not that difficult.
                      • medeekM
                        medeek
                        @Sdmitch: I'm testing your Subtract tool you sent me a while back and it almost works! However when the subtraction breaks the solid group into more than one physical solid then the process seems to break down slightly.
                        In a nutshell I need to be able to do this sort of thing:
                        https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=82746e2c-7867-4de3-8b47-56364b2a6593
                        Where I am subtracting the odd shaped polygonic solid from the cylinder.
                        This last week has been challenging working on the polygon tool for the foundation plugin, I've made some real progress, thanks in a large degree to the continual help and encouragement from Sdmitch, Garry K, TIG and Facer. I'll readily admit my actual SketchUp programming skills are very weak whereas my ideas are very big, it sometimes amazes me I've gotten as far as I have with these two plugins. The fact that I am able to lean on others for some help on occasion has made all the difference.
                        design.medeek.com
                        • sdmitchS
                          sdmitch
                          Yes, I see where it would since it the opposite of what you are trying to accomplish with the slab and rebars. I will PM you the interactive tool version of the plugin I demonstrated in my previous post.
                          • medeekM
                            medeek
                            I'm still digging through the code you sent me. It may take a week but I will attempt to figure out how this actually works. Its amazing how much you are able to compress into such a small body of code.
                            design.medeek.com
