    Making a hole in a group with multiple subgroups
    5 Posts 3 Posters 1.1k Views 3 Watching
    • B
      biervat
      I'm writing a script to make a hole in a group with multiple subgroups.
      I iterate through the group and subtract a box if they intersect.
      The boxes are created correctly but it gives the following error:
      #<Deleted Entity:0x65d174a8>
      Error: #<TypeError: reference to deleted Group>
      def addhole(beginx,beginz,breedte,hoogte)
          #beginpunt x = afstand tot begincoordinaat muur; y = hoogte tov nulpas
          dikte = @wandgroep.local_bounds.depth
          openingbound = Geom;;BoundingBox.new
          openingbound.add([beginx,0,beginz],[beginx + breedte,dikte,beginz + hoogte])
          points = [
              [beginx,0,beginz],
              [beginx,0,beginz + hoogte],
              [beginx + breedte,0,beginz + hoogte],
              [beginx + breedte,0,beginz]
          @wandgroep.entities.to_a.each do |element|
            if not openingbound.intersect(element.bounds).valid?
              if element.typename == 'Group'
                if element.manifold?
                  opening = @wandgroep.entities.add_group
                  opening.entities.add_face(points).pushpull(dikte)
                  result = opening.subtract(element)
                else
                  element.entities.to_a.each do |subelement|
                    opening = subelement.entities.add_group
                    result = opening.subtract(subelement)
        The error-message usually includes a line number.
        That helps you find where things are going wrong...
        It seems to relate to a missing Group ??
        A few ideas...
        @wandgroep
        what is it ?
        Is @wandgroep.valid? when the code runs ?
        If not return ??
        @wandgroep.entities.to_a.each do |element|...
        perhaps add an extra line at the start of that block...
        next unless element.valid?
        so only valid elements get processed...
        PS: I swapped your [ruby] tags for [code] to make it indent and be easier to read...
        • Dan RathbunD
          Dan Rathbun
          For faster speed, change:
          with:
          if element.is_a?(Sketchup::Group)
          Reason: Ruby string comparison is slow, but object identity is fast.
          I'm not here much anymore.
          • B
            biervat
            Yes @wandgroep is a group containing several groups which contain several manifold groups.
            the error occurs in the line "opening = subelement.entities.add_group" after the first subtraction is done. When I delete the subtract line, I don't get the error and every cube is drawn correctly in the correct group.
            It looks like all subelement are deleted after I subtract the first subelement.
            • B
              biervat
              I've found the problem. It was in line "opening = subelement.entities.add_group"
              I created a group inside the group I wanted to subtract.
