    [PLUGIN]MITSUBA Render Exporter v1.5.0(20141109)
    102 Posts 18 Posters 200.2k Views 18 Watching
      bluecd
      This is great, thank you !
      Are you a programmer - if not-where did you learn Ruby?
      May other develope your code?
      cheers,
      • Didier BurD Offline
        Didier Bur
        This is not directly related to this plugin (I think), but after having installed Mitsuba 0.5.0, I always get this message when loading a scene (no matter its version):
        The offending line is the one with the "scene version" property:
        <?xml version="1.0" encoding="utf-8"?>
        <scene version="0.5.0">
        	<integrator type="irrcache">
        		<integer name="resolution" value="6"/>
        And the last lines of the log are:
        2015-09-27 19;05;41 INFO  load [sceneloader.cpp;101] Parsing scene description from "C;\Users\bur\Dossiers\Exercices\Mitsuba\Scenes\sponza\sponza.xml" ..
        2015-09-27 19;05;41 WARN  load [scenehandler.cpp;807] Warning in file "" (line 0); (null)
        2015-09-27 19;05;41 DEBUG load [Thread] Thread "load" has finished
        I've tried lot of things to find a solution, no luck 😞
        Anyone has encountered this ?
        DB
          driven
          I got this message
          The requested scene file is from an older version of Mitsuba (0.4.0). To work with version 0.5.0, it will need to be updated. If you continue, Mitsuba will perform a fully automated upgrade (note that a backup copy will be made).
          Proceed?
          so here's the files it produced...does this one work?
            Didier Bur
            Thanks Driven,
            No this one doesn't work. I had tried to change the version number of my sponza.xml, no luck, and with yours I'm getting the same error 😞
            DB
              driven
              what about the .bak version, which is the original 0.4.0...
                Didier Bur
                Hi John,
                No, the bak file doesn't work either. I suppose that the scene file is OK but that there is something wrong with my Mitsuba installation or configuration...
                DB
                  bluecd
                  Hi again,
                  I guess your still much busy but if could just take a look on some error that occured
                  while exporting to Mitsuba:
                  http://www.pasteall.org/pic/94792
                  OR
                  [TriMesh] Encountered an invalid format !
                  Ive noticed its somehow mentioned earlier BUT..I used just PNG texture and thats the only texture in the model so far. PNG incl. transparency (its a metal mesh texture w/alpha).
                  no idea why it happens but it happens.
                  it kill my arch.work at the moment (((
                  cheers,
                  bcd
                  • E Offline
                    ExpertBeater
                    a recent render of an interior scene 10mn to render,
                    http://img15.hostingpics.net/thumbs/mini_178479tomodify3.jpg
                    • E Offline
                      ExpertBeater
                      @tak2hata thank you for the implementation of mitsuba in sketchup,
                      there is a possibility to add "blend material" to the exporter : a material that mixes between two others with a blend factor or with black/white texture
                      • majidM Offline
                        majid
                        Why the exporter is not developing anymore?
                        • 6 / 6
