    Measuring on a curved line
    6 Posts 3 Posters 582 Views 3 Watching
    • F Offline
      Fancey
      This is my first post, so I may be in the wrong forum. Sorry in advance if so. I am looking for the analogy to either or both the divide command and tape measure tool applied to a curved line. I need to divide and make measurements along a curved line. I am aware of the length in the entity info, and can make some use of it. Also, I tried the poly line segmenters, but the integrity of the curve changes. Maybe I don't understand the results. Any help to point me in the right direction will be much appreciated.
      • gillesG Offline
        gilles
        Do you speak of native curves (arc,circle ) or custom curves like bezier or welded segments?
        • F Offline
          Fancey
          Hi Gilles,
          I'm using bezier and welded curves.
          Fancey
            You want make this sort of things ?
            • F Offline
              Fancey
              Hi Frenchy,
              Thanks. This will do it.  I can create a marker which I can copy along the curve, and the segments between markers are what I'm looking for.
              Thanks again. So helpful.
              Fancey
                I was sure that you can make that you want with this! β˜€
                A very cool plugin! THX Anton! πŸ‘
