    Help please. How to get transformation for the face
    10 Posts 6 Posters 2.7k Views 6 Watching
    • C
      cesaro36
      Hi everyone
      I need help to get the transformation of the current face under the cursor.
      I'm using the input point method but my problem emerges when the cursor is Inferenced.
      It is weird because my @ip.face is correct but @ip.transformation doesnt match.
      I dont use a pick helper because I need to get faces outside p.e. when editing inside a component.
      The only plugin that I've seen it managing well is AngleInpector from Freddo tools.
      Any ideas?
      get transformation
      • sdmitchS
        sdmitch
        @ip.transformation would be the transformation of the parent of the face not the face itself.
        http://sdmitch.blogspot.com/
        • C
          cesaro36
          thanks, but... what I mean is how to get the correct transformation for the face bellow when the cursor is inferenced. Is there something I'm missing?
            A face doesn't have a "transformation" per se.
            The "input point" your identify can give the transformation of where it was picked - which you can then use to modify entities' transformations later...
            You can "transform" a group/instance, face, edge or vertex...
            You can gather various info about any picked vertex/edge/face [e.g. position/line/center/normal ] - and devise transformations to modify these [bearing in mind the parent's transformation you have also collected...]
            BUT what do you want to do ?
            Please explain what you want to 'find' and what you want to do with it...
            • C
              cesaro36
              Thanks TIG
              My intention is to highlight the face that the cursor is passing over.
              In the Animation GIF you can see that when the interfering is happening the highlighted face is been drawn where it should'n, meaning that the transformation given by @ip.transformation is not the same as it was before the iterferencing while the @ip.face is still the same. (is that make sense)
              I'm doing my best trying to explain this in english.
              • Dan RathbunD
                Dan Rathbun
                @cesaro36 said:
                Thanks TIG
                You can do this easily by pushing the face's reference into the model selection set.
                old_set = model.selection.to_a model.selection.clear model.selection.add(@ip.face)
                I'm not here much anymore.
                • C
                  cesaro36
                  Thanks Anton
                  I'll try it as soon as I get to my laptop.
                  • T
                    TBoy
                    Anton_S,
                    Do you have similar code to highlight local bounding boxes (including those inside groups and components)?
                      Anton_S
                      cesaro36,
                      Like TIG and others mentioned a face doesn't have a transformation, but its point positions are bound to the transformation of a group/component instance containing the face. In that case, you will need to transform all points of the face into global space before highlighting the face.
                      Here is a sample face highligher tool:
                      class FaceHighlighterTool
                        def initialize
                          @ip = Sketchup;;InputPoint.new
                          @triplets = []
                          @edge_points = []
                          @hovered_face = nil
                          @hovered_face_tra = nil
                          @face_color = Sketchup;;Color.new(0,40,255,80)
                          @edge_color = Sketchup;;Color.new(0,0,255,255)
                          @edge_width = 3
                        def deactivate(view)
                          @hovered_face = nil
                          view.invalidate
                        def onMouseMove(flags, x, y, view)
                          @ip.pick(view, x, y)
                          face = @ip.face
                          if face.nil?
                            if @hovered_face
                              @hovered_face = nil
                              view.invalidate
                            return
                          if face != @hovered_face
                            @hovered_face = face
                            @hovered_face_tra = @ip.transformation
                            # In order to draw a face with holes, we must draw its mesh
                            mesh = face.mesh
                            polygons_size = mesh.count_polygons
                            @triplets = Array.new(polygons_size)
                            for i in 0...polygons_size
                              # Obtain one of the triangles making up the face
                              triplet = mesh.polygon_points_at(i+1)
                              # Transform to global space
                              triplet.each { |pt| pt.transform!(@hovered_face_tra) }
                              # Store for drawing
                              @triplets[i] = triplet
                            # Get all edges for drawing a border
                            @edge_points.clear
                            face.edges.each { |edge|
                              @edge_points << edge.start.position
                              @edge_points << edge.end.position
                            # Transform all edge points to global space
                            @edge_points.each { |point| point.transform!(@hovered_face_tra) }
                            # Trigger the drawing
                            view.invalidate
                        def draw(view)
                          return unless @hovered_face
                          view.drawing_color = @face_color
                          @triplets.each { |triplet|
                            view.draw(GL_POLYGON, triplet)
                          view.drawing_color = @edge_color
                          view.line_width = @edge_width
                          view.line_stipple = ''
                          view.draw(GL_LINES, @edge_points)
                      end # class FaceHighlighterTool
                      Sketchup.active_model.select_tool(FaceHighlighterTool.new)
                      If you paste it all into Ruby Console you will see the effect.
                      Anton
                        Anton_S
                        There it is, TBoy:
                        class BoundsHighlighterTool
                          def initialize
                            @hovered_inst = nil
                            @global_parent_tra = nil
                            @global_bb = nil
                            @labb_global_faces = [] # Faces for the local axes aligned bounding box.
                            @gabb_global_faces = [] # Faces for the global axes aligned bounding box.
                            @labb_global_edges = []
                            @gabb_global_edges = []
                            @labb_face_color = Sketchup;;Color.new(255,40,0,80)
                            @gabb_face_color = Sketchup;;Color.new(0,40,255,80)
                            @labb_edge_color = Sketchup;;Color.new(255,0,0,255)
                            @gabb_edge_color = Sketchup;;Color.new(0,0,255,255)
                            @edge_width = 3
                            reset(view)
                            ip_path = @ip.instance_path
                            if ip_path.empty?
                              reset(view)
                              return
                            inst = nil
                            gptra = nil
                            ip_path.each { |ent|
                              break if !ent.is_a?(Sketchup;;Group) && !ent.is_a?(Sketchup;;ComponentInstance)
                              if gptra
                                gptra = gptra * inst.transformation
                              elsif inst
                                gptra = inst.transformation
                              inst = ent
                            unless inst
                              reset(view)
                              return
                            return if inst == @hovered_inst
                            @hovered_inst = inst
                            @global_parent_tra = gptra
                            local_bb = @hovered_inst.bounds
                            # Obtain corners of local axes aligned bounding box in global space
                            lagc = []
                            for i in 0..7
                              lagc << local_bb.corner(i)
                            if @global_parent_tra
                              lagc.each { |point| point.transform!(@global_parent_tra) }
                              [lagc[0], lagc[2], lagc[3], lagc[1]],
                              [lagc[4], lagc[6], lagc[7], lagc[5]],
                              [lagc[1], lagc[0], lagc[4], lagc[5]],
                              [lagc[2], lagc[3], lagc[7], lagc[6]],
                              [lagc[0], lagc[2], lagc[6], lagc[4]],
                              [lagc[3], lagc[1], lagc[5], lagc[7]]
                              lagc[0], lagc[2],
                              lagc[2], lagc[6],
                              lagc[6], lagc[4],
                              lagc[4], lagc[0],
                              lagc[3], lagc[1],
                              lagc[1], lagc[5],
                              lagc[5], lagc[7],
                              lagc[7], lagc[3],
                              lagc[0], lagc[1],
                              lagc[2], lagc[3],
                              lagc[4], lagc[5],
                              lagc[6], lagc[7]
                            # Create global axes aligned bounding box
                            @global_bb = Geom;;BoundingBox.new()
                            @global_bb.add(lagc)
                            # Obtain corners of global axes aligned bounding box in global space
                            gagc = []
                            for i in 0..7
                              gagc << @global_bb.corner(i)
                              [gagc[0], gagc[2], gagc[3], gagc[1]],
                              [gagc[4], gagc[6], gagc[7], gagc[5]],
                              [gagc[1], gagc[0], gagc[4], gagc[5]],
                              [gagc[2], gagc[3], gagc[7], gagc[6]],
                              [gagc[0], gagc[2], gagc[6], gagc[4]],
                              [gagc[3], gagc[1], gagc[5], gagc[7]]
                              gagc[0], gagc[2],
                              gagc[2], gagc[6],
                              gagc[6], gagc[4],
                              gagc[4], gagc[0],
                              gagc[3], gagc[1],
                              gagc[1], gagc[5],
                              gagc[5], gagc[7],
                              gagc[7], gagc[3],
                              gagc[0], gagc[1],
                              gagc[2], gagc[3],
                              gagc[4], gagc[5],
                              gagc[6], gagc[7]
                            view.invalidate
                          def draw(view)
                            return unless @hovered_inst
                            # Draw local axes aligned global bounding box
                            view.drawing_color = @labb_face_color
                            @labb_global_faces.each { |face|
                              view.draw(GL_POLYGON, face)
                            view.drawing_color = @labb_edge_color
                            view.draw(GL_LINES, @labb_global_edges)
                            # Draw global axes aligned global bounding box
                            view.drawing_color = @gabb_face_color
                            @gabb_global_faces.each { |face|
                            view.drawing_color = @gabb_edge_color
                            view.draw(GL_LINES, @gabb_global_edges)
                          def reset(view)
                            return false unless @hovered_inst
                            @hovered_inst = nil
                            @global_bb = nil
                            @labb_global_faces.clear
                            @gabb_global_faces.clear
                            @labb_global_edges.clear
                            @gabb_global_edges.clear
                            view.invalidate
                            return true
                        end # class BoundsHighlighterTool
                        Sketchup.active_model.select_tool(BoundsHighlighterTool.new)
                        This time we iterate through the InputPoint's instance_path and transform the bounding box of the deepest instance across all the the parent groups/component instances in the path.
