    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
      Anton_S
      @synsuka3d said:
      Add joystick(:rightz) and joystick(:leftz) for joy(RT) and joy(LT) please.
      for xbox controler.
      Roger that!
        Anton_S
        Hi, SynSuka3D,
        I fixed it and added rightz/leftx commands.
        You can download the WIP version here: https://drive.google.com/open?id=0B3qg8f4WrNdHUmE5OXNiWjQ0Vzg
        You can try out the joystick controller test model attached below.
        Best regards,
        Anton
        Joystick.skp
        • F Offline
          faust07
          Should make my question more precise:
          The reason for the loose behaviour of the joints is the update rate in MSPhysics UI - Simulation - Update Rate = 1 (seems the best for my large model).
          If I change this from 1 to 3, the servos remain more stable in the pivot but the spring no longer brings the steady up and down movement.
          Have now tried to modify all settings at the Spring Joint, but do not get the desired result.
          What can I do?
          Thank you in advance, Anton!
          Update Rate 1
          Update Rate 3
          Servo-Spring-Test
          • luckyvacL Offline
            luckyvac
            Hi Anton and the community,
            I think I have found the solution to control the damping of the servo motor. I worked on the geometry of "green" parts to decrease the sensitivity to the vibratory modes. As we can do in reality.
            It's impressive !
            Best regards. 😄
            luckyvac
            main gauche MOV 03.skp
            • F Offline
              faust07
              Unfortunately, changing the Update Rate from 1 to 3 is not useful when camera, joints, emitter, etc. are based on scripts that use the OnUpdate function. Programmed objects become 3 times faster. The appearance of emitted objects no longer fits to the image rate. The weight of the emitted objects or the lifetime seems to change.
              For the joints based on pivot points, an option independent of the Update Rate in the user interface seems to be useful for fixing at the pivot point. If this is possible...
                SynSuka3D
                @Anton_S goood xbox controller Merci!
                  SynSuka3D
                  @Anton_S
                  @body.set_omega([Internal body axis , 0, axes in global space]) ???
                  ex:
                  *onStart{
                  @body = simulation.find_body_by_name('body')
                  onUpdate{
                  r_body = @body.get_matrix
                  ax = Geom::Vector3d.new([key('up'), 0, 0]).transform(r_body)
                  @body.set_omega([ax.x, 0, key('right')])
                    TheSniper
                    Platform: Sketchup 2017 on Mac 64 bit
                    Anton,
                    Got the update, (Thank you) I have not gone thru all the settings as of yet. But so far it appears to working as expected. Ill let you know as soon as I can get thru all the settings THANKS! -S
                      Anton_S
                      SynSuka3d, like I said, you should reference the scripting documentation to see what each function does: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/MSPhysics/Body#set_omega-instance_method
                        SynSuka3D
                        my project
                        https://media.giphy.com/media/l3q2Ugf90Umd7h2Ss/giphy.gif
                        • F Offline
                          faust07
                          A little question regarding Export Replay to SkIndigo: The batch rendering doesn't save the frames complete rendered after the set Halt time but at the point of the last image update during the render process. This point can be minutes before the desired render time per frame. Is it an exporter question or should I ask in the Indigo forum?
                            Anton_S
                            @Faust, I don't know. I need to look deeper into that.
                            • luckyvacL Offline
                              luckyvac
                              HI,
                              Here is the robot hand with 22 servo.
                              Best regards
                              luckyvac
                              main gauche MOV 04.skp
                              • F Offline
                                faust07
                                OK, thank you.
                                Have tested MSPhysics "Export Replay to Images" with the new SketchUp Make 2017 M2 (windows 7) and got a similar result as with M1 (windows 10) as mentioned in an older question.
                                The example is a GIF of exported frames with an original resolution 1920x1080.
                                all frames with grey parts
                                  SynSuka3D
                                    Anton_S
                                    The "update rate" option controls the amount of times the simulation is to be updated per frame.
                                    An update rate of 3, for example, tells the newton world to update 3 times a frame.
                                    Now, to answer your question, the behavior of onUpdate event was changed in 0.9.9; instead of being called one time every frame, it was changed to be called every time the world is updated. Thus, it is updates "update rate" times every frame. To fix your problem, use onTick event instead of onUpdate. It is triggered only once every frame. See this link for all the events: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/MSPhysics/BodyContext
                                    @faust07 said:
                                    OK, thank you.
                                    The "Export Replay to Images" uses SketchUp's view.write_image function to export view into a 2d graphic. I don't think I have control over how the image is exported. Perhaps it's a SketchUp related bug. Or, since it also doesn't render fully with Indigo, it could be your hardware, not having enough memory/processing power (not much of an expert in this), to export a full image. Try exporting replay of a simple model, with only a few geometric objects, with resolution set to 1920x1080, and see if it exports properly.
                                      Anton_S
                                      What can I do?
                                      I will fix that improper behavior of a spring joint.
                                      Edit: Actually the spring joint works as expected. It was the oscillator function not considering the update rate. I will change the oscillator function to multiply by elapsed time (in seconds), rather than frame, which are two different things.
                                      Edit2: Here is the new oscillator function: You can edit the MSPhysics/common_context.rb and replace the last method with this new one:
                                      # Get oscillated value of a sine curve.
                                      # @param [Numeric] frequency Number of sine periods per second.
                                      # @return [Numeric] A value ranging between -1.0 and 1.0.
                                      def oscillator(frequency)
                                        inc = frequency * 2 * Math;;PI
                                        Math.sin(inc * MSPhysics;;Simulation.instance.world.time)
                                      Note that you will have to retweak the oscillation frequencies for your birdy.
                                        Anton_S
                                        @luckyvac said:
                                        HI,
                                        Best regards
                                        luckyvac
                                        Luckyvac, this arm is very unstable with MSPhysics. This could be tweaked to be a bit more stable, but it won't be suitable to play a guitar. A programmers approach to creating a guitar would be to fake the arm and finger movements with animation rather than using the actual simulation. But that, then requires a lot of time. What I suggest you do, is look for a different software online, that emulates arm movements and guitar sounds. I'm positive that such software exits.
                                        • F Offline
                                          faust07
                                          Thanks, Anton for the explanations.
                                          The Indigo renderer update/halt time difference seems not to be a MSP or hardware problem. I've tested it with different model sizes on different machines. I'll try to ask this in the Indigo forum. In the SkIndigo Render Settings one can set the halt time a few seconds longer than the before tested update time and all is fine.
                                          The incomplete results of the view.write_image function in SketchUp 2017 I will report in the SketchUp Community Forum.
                                          I hope my problems with Servos I can demonstrate in the following examples more dramatically. A mode to hold connected objects in the pivot position would be fine.
                                          The tests with the Update Rate I did only to improve that. No need to change the oscillator script. For non real time simulations (large models with much MSP-objects) the oscillators based on frames are better than based on world time. (on the end the film with 30 frames per second brings the "real time" feeling).
                                          Servo-Test_06s.skp
                                            SynSuka3D
                                            Final base
                                            3D Warehouse
                                            (3dwarehouse.sketchup.com)
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 46
                                            • 47
                                            • 29 / 47
