    "magic wand"
    13 Posts 4 Posters 3.6k Views 4 Watching
    • seraleklee1S
      seraleklee1
      Thanks, I tried SKM Tools, installed in SketchUp 2017, but I can not make it work.Java.JPG
      • JQLJ
        JQL
        Well... can't help you any more. You can try contacting Tig or expose the issue in the plugin discussion thread.
        www.casca.pt
        Visit us on facebook!
          Use SU 2016! πŸ˜‰
          Tig has maybe not yet enough time to adapt all its plugs to the 2017!
          Else you can make something like this πŸ˜„
          In any 2D Prog Fill black your PNG image except bakground!
          Call Inkscape (free)
          Open your "Black" image
          Menu Path / Vectorize Bit Map
          Save as DXF
          In SketchUp Free DXF import the DXF by Jim
          Et voilΓ ! πŸ˜„
          https://s6.postimg.org/bgnnt2ydt/truc.jpg
          • seraleklee1S
            seraleklee1
            Thanks, I was hoping for a plugin that would make up the process
              @seraleklee1 said:
              Thanks, I tried SKM Tools, installed in SketchUp 2017, but I can not make it work.[attachment=0:2opylaoq]<!-- ia0 -->Java.JPG<!-- ia0 -->[/attachment:2opylaoq]
              As explained in the usage...
              This old version uses Java to manipulate some of the image file's data using small .jar applets which must be enabled in Java to be executable.
              Some compression/decompression apps might hijack .jar file-types and cause issues...
              Sadly your Java error-message is not very useful.
              You must also follow the guidance regarding the PNG image, and make all needed pixels opaque and the unwanted background transparent pixels - use PhotoShop, Gimp etc...
              • seraleklee1S
                seraleklee1
                Yes, the pictures that I have tried are in png format, with transparent pixels outside the figure. The plugin creates a folder to end the generated files, (C: \ Users \ XEON \ Documents \ TrimmedImages) are always in png format have only suffered a cut, but have not identified the contours to be deleted. Probably I'm wrong a few steps.
                • seraleklee1S
                  seraleklee1
                  Thanks, I followed the procedure that you indicated to me, however, using Inkscape and it works. I vectorized image to black and white and exported in DXF. Unfortunately for me the plugin does not work and I will need a long time to do the job with Inkscape.
                  • seraleklee1S
                    seraleklee1
                    😳 The most obvious thing to do I had not done. Updating Java to the latest version, the plugin "Image Trimmer" works perfectly!
                    thank you and excuse me 😳
                    • JQLJ
                      JQL
                      I'm wondering if you really need the plugin for this work. Why do you need the contour if you already have the image you need?
                      A renderer will use the image's transparent pixels for visibility and shadows. In sketchup you can hide the rectangle's profile edges and you can turn off cast shadows from the rectangle. Then, inside the component, you can have a face/model, with the average shape of your image, and make it cast shadows. You paint both with the image and it's done.
                      You have a rough model with shadows and a perfect cutout image with perfect pixels, like this:
                      Example SU8.skp
                      Click the gif:
                      www.casca.pt
                        In fact you have nothing to do, the render makes the good result directly! πŸ˜„
                        Here with the Free Visualizer (works till 2016)
                        • JQLJ
                          JQL
                          For architects rendering output is needed, but sketchup output might be also worthy. I want my trees to project shadows, so I can study the project.
                          There is also the fact that cast shadows from a 2d face me component, isn't compatible with renderers and sometimes you get thin flat shadows as shadows don't face sun. In my proposed solution the 2nd model can be a fairly rough 3d which casts 3d shadows that work.
                          You can check a bit more about it here:
                          404 Not Found
                          (sketchucation.com)
                          www.casca.pt
