    Quantity Reports
    3 Posts 2 Posters 603 Views 2 Watching
    • N Offline
      Nauzer67
      I am trying to use Sketchup to give me a report on componets that I am using to model a insulated styrofoam foundation.I have 3 componets: a corner, a standard block, and an adjustable length block which is used to fill in between the standard blocks and the corner. Some of these blocks are copied and moved and some are grabbed from my componet library. When I run a report some blocks are grouped while others are each on a seperate line. Is there any way to control what gets grouped and what is on its own line? I need my adjustable componets to each be on a seperate line so I can add the total length of all these componets and divide it by the length of a standard block to get my actual quantity. Help please..
      sample report and model
      FoundationSample.skp
      • sdmitchS Offline
        sdmitch
        If possible, post a sample model in version 8.
        http://sdmitch.blogspot.com/
        • sdmitchS Offline
          sdmitch
          Perhaps this will help. Rather than putting each cut block on a separate line, I did the addition for you. If this is acceptable I will send you a copy of the plugin by Private Message.
