    3D Truss Models
    1.5k Posts 31 Posters 976.9k Views 30 Watching
    • medeekM Offline
      medeek
      I like the new addition of the layers, it helps being able to hide certain aspects of the model. This has led me to think it might be useful to somehow implement materials (colors, textures), either at the layer level or based on the geometry (ie. specific color or texture for the I-joist web -> OSB wood).
      http://design.medeek.com/resources/images/truss_su14_800.jpg
      For now I don't think I will make the material assignment(s) customizable, in the global settings you will be able to turn it on or off, if it is turned on then I will have the plugin assign some fairly generic colors for lumber, pressure treated lumber and texture for OSB sheathing. Metal plates will be assigned a texture as well, this should be rather interesting.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ Offline
        juju
        Thanks for the upgrades! I'm on holiday and am looking forward to this when I'm back at the grindstone in a few weeks time!
        • medeekM Offline
          medeek
          Version 1.7.3 - 12.17.2016
          • Added a "Materials" tab within the global settings; Auto material assigment (colors and textures) is now an option.
          • Enabled materials and custom layers for floor trusses and joists.
          • Enabled materials for common trusses: metal plate connectors, lumber, and OSB.
          http://design.medeek.com/resources/images/truss_su167_800.jpg
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          http://design.medeek.com/resources/images/truss_su168_800.jpg
          A big thanks to those on the SketchUcation and SU board who helped me with the custom materials part of the API, the SketchUp community is a great asset.
          By default the metal plate connectors, custom layers and auto materials is turned off in the global settings.
          design.medeek.com
          • medeekM Offline
            medeek
            • Enabled metal plate connectors for floor trusses.
            http://design.medeek.com/resources/images/truss_su169_800.jpg
            View model here:
            3D Warehouse
            The algorithm for the plate placement is fairly complex but not nearly as bad as I thought it would be, just knocking out some low hanging fruit while I'm recovering. The painkillers have kept me a bit off my "A" game so I haven't tackled anything big yet, like the completion of the stepdown hip truss set.
            design.medeek.com
            • medeekM Offline
              medeek
              Looking through some old plans I've managed to dig up I came upon a couple of designs by another engineering firm.
              Typically when I've dealt with truss designs I always seen a scarf cut on the bottom chord with the top chord remaining un-notched. In this other example the bottom chord is kept intact and the top chord is scarf cut or notched, while still allowing a continuous section to extend for the overhang with a depth equal to at least 1/2 the top chord depth. I think the picture below explains this far better than I can with words:
              http://design.medeek.com/resources/images/TIMBER_TRUSS2.jpg
              For MPC trusses I am used to seeing a 1/4" butt cut, however for timber trusses what is more appropriate?
              Which method above would go with (arch. and structural reasons)?
              View model here:
              3D Warehouse
              design.medeek.com
              • medeekM Offline
                medeek
                Plates applied to the top truss:
                http://design.medeek.com/resources/images/TIMBER_TRUSS3.jpg
                Specs:
                • Truss Type: King Post
                • 6x10 TC, 6x8 BC, 6x6 kingpost
                • Plate thickness = 0.25"
                • single row of bolts with two bolts per row.
                • connector plate width = 4.0"
                • Bolt Dia. 3/4"
                • Bolt Edge Distance (timber) = 4.0"
                • Bolt Edge Distance (plate) = 2.0"
                • Bolt Spacing = 4.0"
                • Bolts and Washers not shown.
                View model here:
                3D Warehouse
                design.medeek.com
                • medeekM Offline
                  medeek
                  This particular joint on a gambrel attic roof I am finding particularly difficult to plate:
                  http://design.medeek.com/resources/images/truss_su170_800.jpg
                  Luckily I have a few samples to use as guides. Given my web configurations at this joint this seems to be the most reasonable method to plate this joint. Note that the plate should touch the interior corner and the exterior of the lower top chord but at the same time not project past the lumber into the spaces. Also the plate is rotated so that it is parallel to the upper top chords pitch.
                  The algorithm I devised to do this is quite clever I think but can be boiled down to a few concise lines of code:
                    # Plate 2 (Gambrel Left)
                  	x2 = @W2x2 - (mpcyy)/(sin(@Phi2))
                  	y2 = @W2y2
                  	m2 = tan(@Phi2)
                  	x1 = @X2
                  	y1 = @Y2
                  	m1 = tan(@Phi1)
                  	x0 = (y2 - y1 - m2*x2 + m1*x1)/(m1 - m2)
                  	y0 = y1 + m1*(x0 - x1)
                  	xoffset = (mpcxx/2.0)*(cos(@Phi2)) + (mpcyy/2.0)*(sin(@Phi2))
                  	yoffset = (mpcxx/2.0)*(sin(@Phi2)) - (mpcyy/2.0)*(cos(@Phi2))
                  	mpcx = x0 + xoffset
                  	mpcy = y0 + yoffset
                  	mpcrot = -@Phi2
                  	MedeekMethods.metal_plate mpcx, mpcy, mpcxx, mpcyy, mpcrot, "PLGL"
                  	# Plate 2 (Gambrel Right)
                  	mpcx = @X5 - mpcx
                  	mpcy = mpcy
                  	mpcrot = @Phi2
                  	MedeekMethods.metal_plate mpcx, mpcy, mpcxx, mpcyy, mpcrot, "PLGR"
                  This joint has been the most difficult so far, everything else has been cake.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.7.4 - 12.20.2016
                    • Enabled metal plate connectors for gambrel attic trusses.
                    http://design.medeek.com/resources/images/truss_su171_800.jpg
                    View model here:
                    3D Warehouse
                    design.medeek.com
                    • FrederikF Offline
                      Frederik
                      Merry Christmas to you as well, Nathaniel! 👍
                      http://www.kerkythea.net/users/Frederik/Anim-Icons/xmas.gif
                      Cheers
                      Kim Frederik
                      • medeekM Offline
                        medeek
                        Version 1.7.5 - 12.24.2016
                        • Enabled metal plate connectors for valley truss sets.
                        • Enabled materials and custom layers for valley truss sets.
                        http://design.medeek.com/resources/images/truss_su172_800.jpg
                        View model here:
                        3D Warehouse
                        Merry Christmas to all.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.7.6 - 12.26.2016
                          • Enabled metal plate connectors for monopitch trusses.
                          • Enabled materials and custom layers for monopitch trusses.
                          http://design.medeek.com/resources/images/truss_su173_800.jpg
                          View model here:
                          3D Warehouse
                          I just realized that raised heel option does not work fully with the materials and connectors, I will work on a fix later today to sync that up.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.7.7 - 12.31.2016
                            • Enabled materials and custom layers for gable, hip, shed, TJI and dutch gable rafter roofs.
                            http://design.medeek.com/resources/images/truss_su174_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.7.8 - 01.02.2017
                              • Enabled materials and custom layers for gable dormers.
                              • Added advanced options for gable dormers, enabled exterior wall sheathing option.
                              http://design.medeek.com/resources/images/truss_su175_800.jpg
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Out of curiosity when you architects and designers add hardiplank siding or other types of siding to a building what do you typically do? One could go so far as modeling the sawtooth/washboard of the siding but this would become very heavy in the model. I'm assuming most just use a material/texture to simulate the effect.
                                On a slightly different note I am looking for a really good texture to use for concrete in my other plugins, any suggestions?
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  This is an example of custom layers and materials implemented in the Medeek Truss Plugin and Medeek Foundation Plugin and used in one model:
                                  http://design.medeek.com/resources/images/truss_su176_800.jpg
                                  View model here:
                                  3D Warehouse
                                  Turn off the sheathing layers first to reveal all of the structural framing etc...
                                  Regular walls were created with the Housebuilder plugin.
                                  The trim tool in the Truss Plugin was used quite successfully to manually trim back the dormer roof framing and sheathing.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Neck is doing pretty good these days, a little sore some mornings but nothing a little Ibuprofen can't fix.
                                    On the flip side I came off of the Hydrocodone (for the neck and shoulder pain) about two weeks ago but still suffering from the withdrawal symptoms from this drug. My advice, don't ever use Hydrocodone unless it is absolutely life or death, its just not worth it.
                                    I'm trying to figure out what to tackle next.
                                    design.medeek.com
                                    • pbacotP Offline
                                      All looking great! Glad your neck is better. (I don't know what you've got or what you've been doing about it: I used exercises on mine which seemed good, along with general exercise. And I use a foam neck pillow. Just in case you're looking for ideas.)
                                      • medeekM Offline
                                        medeek
                                        Tonight I spent some time trying to do some "real world" modeling and it quickly becomes apparent how limiting the plugins really are. Take a look at this model here:
                                        3D Warehouse
                                        I need the ability to cut holes in the floors and insert headers and double up joists etc...
                                        There is a serious need for a good staircase plugin, but maybe that already exists, either way it would be handy to have that part of the truss plugin or wall plugin.
                                        Where roofs merge into other walls requires some attention.
                                        I really need to get to work on the wall plugin, I'm using Housebuilder but I have a lot of features I would like to see to make it more flexible and reliable.
                                        The double glulam beam rafter roof would be a nice addition as well.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Fixed a small bug in the valley truss set, hence the revision 1.7.8b. Hopefully tonight I can attack the timber truss module, I think I have most of the pseudo code put together.
                                          design.medeek.com
                                            Garry K
                                            My stair maker plugin creates straight and curved stairs. Also Spirals.
                                            I am intending on adding quarter and half landings and some other features.
                                            I have built more than 200 of these geometric stairs including elliptical, specialty winders etc.
                                            We also specialized in framed up curved stairs without the cost of stringers.
                                            Some of my stairs projects include providing the bending forms and flattened stringers.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 75
                                            • 76
                                            • 26 / 76
