    Pdf to sketchup
    6 Posts 3 Posters 931 Views 3 Watching
      Poot
      Hi guys,
      I'm trying to import a pdf into sketchup i know this is possible by using inkspace,
      and following this tutorial ( http://sketchucation.com/resources/tutorials/intermediate/426-pdf-skp-conversion)
      But when i follow this tutorial and import the pdf file into sketchup nothing appears...
      Pdf and dxf file in attachment.
      What am i doing wrong and how can i fix this?
      Thanks in advance,
      Sam
      ex.pdf
      ex.dxf
        Poot
        ok thanks for the info!
        But how is this fixable?
        I really need to import this into sketch up because i need to make a 3d model of it.
          As you have a pro version you can reload the DXF result of my post above! ๐Ÿ˜„
          • srxS Offline
            srx
            If it is not in vector format just convert PDF to image and import it in SU for manual tracing. You will first have to scale it to original size with Tape measure tool though.
            www.saurus.rs
              Seems your PDF and DXF are not "vectorized" file!
              So first clean your image erase shadows, dash lines etc et the maximum !
              then
              https://www.vectorizer.io free vectorise on line
              so you have svg file format
              so Convert it online
              https://convertio.co/fr/svg-dxf/ free convert on line
              so you have a DXF file format reloadable in SketchUp!
              Bonne chance! ๐Ÿ˜„
                Poot
                Thanks for all the reply's guys, i will try them all.
                And let you know how it turned out!
