π« Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
Add name to a propertie
Hello
Is it possible to name a shape or a dimension into a component?
Let suppose I have a rectangle with many round holes.
Is it possible to name some of the hole's diameters, so I can change them, and only the ones with that name, with a script ?Thank for help.
I am not a Ruby man but I suppose you can!
Just use Group(s) or Component(s)
Here Goups! Rectangle is not a Component, but that will be the same with a Rectangle Component! (Edit Component...)
Hello pilou
I dont have the same view.
When I select the circle, I have no name field in the entity info.
How can I display the sructure of the group ?
Sorry I couln't uploaded any screen print...
