    [Code] Skew Transformation from axes
    21 Posts 8 Posters 5.3k Views 8 Watching
    • fredo6F Offline
      ...and there is the magic formula by thomthom to check if two faces are coplanar (actually have parallel planes)
      face1.normal % face2.normal > 0.9999999991
      • eneroth3E Offline
        eneroth3
        That's a nice one! When making my upright extruder I first tried the samedirection? method but it has some issues with the precision and see faces as co-planar sometimes when they aren't (just as the built in Soften Edges feature). Instead I looped the vertices on one face and used classify_point on the other face to see if any vertex position were considered not on plane. In the future I'll use this instead!
        My website: http://julia-christina-eneroth.se/
        • icehuliI Offline
          icehuli
          I have never known this operator "%" on vectors. ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ Fredo, could you explain to me how it works....
          • Dan RathbunD Offline
            Dan Rathbun
            @icehuli said:
            I have never known this operator " %" on vectors....., could you explain to me how it works....
            Geom::Vector3d#%()
            is an alias for the dot() method, ie:
            Geom::Vector3d#dot()
            (https://en.wikipedia.org/wiki/Dot_product)":dlvmfrbf]
            Geometrically, it is the product of the Euclidean magnitudes of the two vectors and the cosine of the angle between them. The name "dot product" is derived from the centered dot " ยท " that is often used to designate this operation; the alternative name "scalar product" emphasizes that the result is a scalar (rather than a vector).
            I'm not here much anymore.
            • fredo6F Offline
              Dot product is 0 if the vectors are perpendicular.
              It is 1 if they have the same direction (assuming they are normalized) and -1 for opposite direction.
                Dan Rathbun
                @fredo6 said:
                "assuming they are normalized"
                Does normalizing first remove any variance that could throw off the comparison (with -1, 0 or 1) afterward ?
                Or would it be safer to use:
                vec1.perpendicular?(vec2)
                vec1.parallel?(vec2) && vec1.samedirection?(vec2)
                vec1.parallel?(vec2) && ! vec1.samedirection?(vec2)
                I also wonder about ThomThom's magic comparison.
                Is it the same on 64-bit SketchUp ?
                I mean why 10 decimal places ? Is it SketchUp's internal tolerance ?
                Ie, (0.001 x 0.001 x 0.001) ... which is 9 decimal places.
                • sdmitchS Offline
                  sdmitch
                  If you have a component instance that has been skewed, how do you determine which axis is skewed?
                  http://sdmitch.blogspot.com/
                    hm... this must be something from and old version of CleanUp? It was never reliable. What I do now is take all the vertices of the faces and generate a best-fit plane - then I check if each of the vertices is on the plane.
                    • fredo6F Offline
                      Well, I think I found it it an old post!. And it seems to work fine for the purpose.
                      Indeed there are alternate methods, the problem being to detect the false positive, that is faces that would be co-planar by the formula, but would not in the model drawn by Sketchup.
                        Dan Rathbun
                        hm... It was never reliable.
                        I was hoping you'd answer the questions I posed (above) in this post:
                        http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=65068%26amp;view=unread#p597160
                        • fredo6F Offline
                          Face.normal returns a normalized vector.
                            Checking the plane might in some cases yield false for some cases where SU is able to merge. But this is rare. Comparing normal had the opposite of yielding true in cases where SU would not be able to merge.
                              As Fredo mentions, face.normal already return a unit vector. The issue is that comparing vectors is too unreliable in edge cases.
                                Dan Rathbun
                                So what is the solution here?
                                Is it some extra text in the API docs explaining how best to test for face coplanarity ?
                                Or would it be a new API method for the Sketchup::Face class:
                                face.coplanar_with?(other_face)
                                or a module method?:
                                Geom::faces_coplanar?(face1,face2)
                                  No sure where it would fit in the docs. Maybe we can add a Wiki section on the GitHub repo that host the new docs.
                                  This scenario is so common though that a face.coplanar_with?(other_face) might be a nice addition.
