    3D Truss Models
    1.5k Posts 31 Posters 937.2k Views 30 Watching
    • medeekM Offline
      medeek
      Version 1.7.4 - 12.20.2016
      • Enabled metal plate connectors for gambrel attic trusses.
      http://design.medeek.com/resources/images/truss_su171_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • FrederikF Offline
        Frederik
        Merry Christmas to you as well, Nathaniel! 👍
        http://www.kerkythea.net/users/Frederik/Anim-Icons/xmas.gif
        Cheers
        Kim Frederik
        • medeekM Offline
          medeek
          Version 1.7.5 - 12.24.2016
          • Enabled metal plate connectors for valley truss sets.
          • Enabled materials and custom layers for valley truss sets.
          http://design.medeek.com/resources/images/truss_su172_800.jpg
          View model here:
          3D Warehouse
          Merry Christmas to all.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.7.6 - 12.26.2016
            • Enabled metal plate connectors for monopitch trusses.
            • Enabled materials and custom layers for monopitch trusses.
            http://design.medeek.com/resources/images/truss_su173_800.jpg
            View model here:
            3D Warehouse
            I just realized that raised heel option does not work fully with the materials and connectors, I will work on a fix later today to sync that up.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.7.7 - 12.31.2016
              • Enabled materials and custom layers for gable, hip, shed, TJI and dutch gable rafter roofs.
              http://design.medeek.com/resources/images/truss_su174_800.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.7.8 - 01.02.2017
                • Enabled materials and custom layers for gable dormers.
                • Added advanced options for gable dormers, enabled exterior wall sheathing option.
                http://design.medeek.com/resources/images/truss_su175_800.jpg
                View model here:
                3D Warehouse
                design.medeek.com
                • medeekM Offline
                  medeek
                  Out of curiosity when you architects and designers add hardiplank siding or other types of siding to a building what do you typically do? One could go so far as modeling the sawtooth/washboard of the siding but this would become very heavy in the model. I'm assuming most just use a material/texture to simulate the effect.
                  On a slightly different note I am looking for a really good texture to use for concrete in my other plugins, any suggestions?
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    This is an example of custom layers and materials implemented in the Medeek Truss Plugin and Medeek Foundation Plugin and used in one model:
                    http://design.medeek.com/resources/images/truss_su176_800.jpg
                    View model here:
                    3D Warehouse
                    Turn off the sheathing layers first to reveal all of the structural framing etc...
                    Regular walls were created with the Housebuilder plugin.
                    The trim tool in the Truss Plugin was used quite successfully to manually trim back the dormer roof framing and sheathing.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Neck is doing pretty good these days, a little sore some mornings but nothing a little Ibuprofen can't fix.
                      On the flip side I came off of the Hydrocodone (for the neck and shoulder pain) about two weeks ago but still suffering from the withdrawal symptoms from this drug. My advice, don't ever use Hydrocodone unless it is absolutely life or death, its just not worth it.
                      I'm trying to figure out what to tackle next.
                      design.medeek.com
                      • pbacotP Offline
                        All looking great! Glad your neck is better. (I don't know what you've got or what you've been doing about it: I used exercises on mine which seemed good, along with general exercise. And I use a foam neck pillow. Just in case you're looking for ideas.)
                        • medeekM Offline
                          medeek
                          Tonight I spent some time trying to do some "real world" modeling and it quickly becomes apparent how limiting the plugins really are. Take a look at this model here:
                          3D Warehouse
                          I need the ability to cut holes in the floors and insert headers and double up joists etc...
                          There is a serious need for a good staircase plugin, but maybe that already exists, either way it would be handy to have that part of the truss plugin or wall plugin.
                          Where roofs merge into other walls requires some attention.
                          I really need to get to work on the wall plugin, I'm using Housebuilder but I have a lot of features I would like to see to make it more flexible and reliable.
                          The double glulam beam rafter roof would be a nice addition as well.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Fixed a small bug in the valley truss set, hence the revision 1.7.8b. Hopefully tonight I can attack the timber truss module, I think I have most of the pseudo code put together.
                            design.medeek.com
                              Garry K
                              My stair maker plugin creates straight and curved stairs. Also Spirals.
                              I am intending on adding quarter and half landings and some other features.
                              I have built more than 200 of these geometric stairs including elliptical, specialty winders etc.
                              We also specialized in framed up curved stairs without the cost of stringers.
                              Some of my stairs projects include providing the bending forms and flattened stringers.
                              • medeekM Offline
                                medeek
                                Spent some time this morning traversing through the common truss code updating some of the truss types so that I can enable energy/raised heels for all common trusses as well as enable custom layers, materials and connector plates.
                                As I've developed the plugin and added new features I used the fink truss as the cutting edge, so everything having to do with this truss type is pretty much up-to-date, however some of the other truss types are seriously lagging so a little house cleaning is in order.
                                It may be a few days before I can release this latest version since there is a lot of tedious work ahead.
                                design.medeek.com
                                • pbacotP Offline
                                  Great work. I wish I had your dedication!
                                  • medeekM Offline
                                    medeek
                                    I will download your stair plugin and give it a go.
                                    That whole spiral staircase thing looks like a real challenge to code, don't even want to go there.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Raised/Energy heels add another level of complexity to the equation. Below you can see that various heights of a raised heel on a simple King Post truss requires different configurations and hence separate plating routines:
                                      http://design.medeek.com/resources/images/truss_su177_800.jpg
                                      This also affects the gable trusses as well, below is a fink truss with its gable counterpart:
                                      http://design.medeek.com/resources/images/truss_su178_800.jpg
                                      View models here:
                                      https://3dwarehouse.sketchup.com/model.html?id=91d8d78a-8e6c-4dab-9839-4d689c84c297
                                      https://3dwarehouse.sketchup.com/model.html?id=89739563-049f-4277-bfca-75663724967e
                                      I'm still house cleaning. I've now got the King Post, Fink and Howe truss fully cleaned up with connector plates enabled for all possible configurations (raised heel, non-raised heel, structural, non-structural). I've only got 9 more common truss types to work through, see list below:
                                      Queen Post
                                      Fan
                                      Mod Queen
                                      Double Fink
                                      Double Howe
                                      Mod Fan
                                      Triple Fink
                                      Triple Howe
                                      Quad Fink
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Raised Heel Howe Truss:
                                        http://design.medeek.com/resources/images/truss_su179_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.7.9 - 01.15.2017
                                          -Enabled metal plate connectors, materials and custom layers for king post, howe and queen post trusses.
                                          • Added energy/raised heels for queen post truss (3 variants: wedge, slider and vertical w/ strut).
                                          • Added energy/raised heels for howe truss (3 variants: wedge, slider and vertical w/ strut).
                                          • Metal plate connectors now enabled for king post, queen post, fink and howe raised heel/energy trusses.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I'm still investigating "real world" applications of the plugin to determine where the weakness and deficiencies are. Here is an example combining a dutch gable rafter roof with some raised heel trusses. Now that the raised heel feature is fully active for many of the common trusses it is actually quite easy to measure and then match the heel height of the rafters.
                                            https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=cc8bdb7c-d8a4-46a7-b9ff-88ac60c6ec07
                                            View model here:
                                            3D Warehouse
                                            I am interested in how others are actually using the plugin and where it is falling down for you, please feel free to send me models or post on the forum with your "real world" design issues with regards to the plugin. This will help drive future development and prioritize the more important items on the todo list.
                                            design.medeek.com
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 75
                                            • 76
                                            • 30 / 76
