    Clean Dynamic Components
    6 Posts 3 Posters 668 Views 3 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      Hello to all. ☀
      The code below removes all the attributes of all Dynamic Components.
      m=Sketchup.active_model;m.start_operation("unDC");m.definitions.each{|d|d.attribute_dictionaries.delete("dynamic_attributes") if d.attribute_dictionaries and d.attribute_dictionaries["dynamic_attributes"];d.instances.each{|i|i.attribute_dictionaries.delete("dynamic_attributes") if i.attribute_dictionaries and i.attribute_dictionaries["dynamic_attributes"]}};m.commit_operation
      How to adapt the code to remove only the component attribute with the definition "Steve"?
      The aim is that all the definitions starting with "Steve" for example copy "Steve # 1", "Steve # 2",
      "Steve # 3" are concerned.
      Do not worry, I do not want nothing wrong with Steve, it's just an example. 💚
      Another research topic, how to remove "sub-components" masked?
      This removal should cover only those components with the definition "Steve" "Steve# 1", Steve#2 "," Steve#3 "...
      Thank you in advance for your help.
      Cordially
      David Barros
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      • Dan RathbunD Offline
        Dan Rathbun
        See this thread in the official "Ruby API" forums:
        Selecting Specific Entity, Group or Component (By Name)
        I'm not here much anymore.
        • TNTDAVIDT Offline
          TNTDAVID
          Thank you Dan for the link. 😉
          Here is the method to select all instances that begins with the definition "Steve":
          n="Steve";m=Sketchup.active_model;s=m.selection;s.clear;m.definitions.each{|d|s.add d.instances if d.name=~/#{n}/}
          Note, Steve can be replaced by any other name.
          How to combine these two codes, to remove all the dynamic attributes of steve component?
          David
          • TNTDAVIDT Offline
            TNTDAVID
            The formula still more simplified:
            m=Sketchup.active_model;s=m.selection;m.definitions.each{|d|s.add d.instances if d.name=~/#{"Steve"}/}
            It activates all the instances that start with "Steve" in Sketchup.
            How to select only the "Steve" in an active component?
            The answer to this question is very important to me!
            Thank you to all those who will want to help me.
            David
              Dan Rathbun
              Don't use the selection. Use an array. Then use one of the Array class' iteration methods.
              • TIGT Online
                Learn to use regular expression matching...
                Dan has provided many useful links to basic Ruby usage...
                d.name=~/Steve/
                matches 'Steve', 'Some Steve', 'Steve#1' etc
                BUT not 'steve' etc
                d.name=~/[Ss]teve/
                matches 'Steve', 'steve' etc
                To limit the match to a start position use
                d.name=~/^Steve/
                matches 'Steve', 'Steve#1' etc
                BUT not 'Some Steve' etc
                To limit the match to an and position use
                d.name=~/Steve$/
                matches 'Steve', 'Some Steve' etc
                BUT not 'Steve#1' etc
                To limit it to an exact match use
                d.name=~/^Steve$/
                matches 'Steve' only, nothing else
                note that is actually equivalent to
                d.name=="Steve"
