    Tables in LO 2017
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    13 Posts 5 Posters 16.5k Views 5 Watching
    • brettsichellodesignB Offline
      brettsichellodesign
      Thought we could go ahead and test the new Tables feature of layout which can supposedly reference a Microsoft Excel or google shreadsheet. I'm pretty excited about this feature as it will save alot of time with window schedules etc...
      However, I am already having trouble with it. I am trying to import a large spreadsheet into LO 2017 and keep getting the following message:
      https://s22.postimg.org/9tvkuhcxt/layouterror.jpg
      I am a Passive House designer and would find this particularly usful for inserting the PHPP spreadsheet into layout. However, every time I try, same error message, even after unprotecting the file.
        brettsichellodesign
        Any advice on this?
        • ntxdaveN Offline
          ntxdave
          @brettsichellodesign said:
          Any advice on this?
          It worked for me.
          Press F1...thank me later
            marcdurant
            Any chance you could share that excel file with the LayOut team for debugging purposes? There may be something specific about your file that's breaking our importer, and we'd love to check it out.
            Thanks,
            Marc
            • N Offline
              nickchun
              Marc, I have had the same issue trialling Layout. I have downloaded the Make version for now. I am trying to insert a table from an Excel 2007 Workbook that has 25 sheets. If you want a copy of the workbook I can PM it to you.
              Nick
                marcdurant
                Yes, I would appreciate any and all files that are causing issues.
                  brettsichellodesign
                  Unfortunately I am unable to share this excel file. However I can confirm that is a 6218KB file with many workbooks most of which are protected. I did try un-protecting them but still have the same issue.
                  I have got round this problem by referencing the cells I needed into a new excel file with just 1 workbook and referencing that into LO. Just means I have to have another file.
                  • jujuJ Offline
                    juju
                    This is probably a noob Excel question, but how do you manage to reference cells in a separate protected Excel file? How do you enter the password to the referenced file from the referring file?
                      brettsichellodesign
                      Please see video below:
                        brettsichellodesign
                        Marc I sent you a PM
                        • jujuJ Offline
                          juju
                          thanks for the vid, that is how you reference cells between documents
                          I'm interested to know if it still works (automatically) if you have the source Excel file password protected and, if so, how you manage that the target file opens/reads the source (password protected) file?
                            marcdurant
                            Among other minutia, looks like the library we're using to import .XLS files doesn't properly handle some aspects of locked cells. Thanks for your help identifying the issue, and keep an eye out for maintenance releases.
                            -m
                            • jujuJ Offline
                              juju
                              -m
                              Hi Marc,
                              When will we be able to reference a password locked Excel file into Layout? I tried again after the SU2017proM2 release but no luck...
