    How to cut from object
    47 Posts 4 Posters 6.9k Views 4 Watching
    • sdmitchS
      sdmitch
      @ado130 said:
      So there are 2 solutions for this (I think)
      1. save somewhere the group where will be notch
      2. find that group somehow
        because, when I do a dril, I'm using this
      		group = nil
      > 		face = nil
      > 		Sketchup.active_model.entities.each{|g|
      > 			next unless g.is_a?(Sketchup;;Group)
      > 			g.entities.each{|f|
      > 				next unless f.is_a?(Sketchup;;Face)
      > 				if f.classify_point(center) == Sketchup;;Face;;PointInside then
      > 					group = g
      > 					face = f
      > 				end
      2.) Exist a way how to find "my" group, where is the rectangular block, when the center point is outside that block?
      Perhaps
      if center.on_plane f.plane then
      	group = g
      	face = f
      http://sdmitch.blogspot.com/
        ado130
        It almost works, but the result is
        http://i.imgur.com/RMnKEB6.png
        def notch(x, y, z, radiuses, depths, directions)
        	model = Sketchup.active_model
        	countOfNotch = x.length.to_i
        	countOfNotch.times do |i|
        		center = [x[i], y[i], z[i]].map(&;to_f)
        		radius = radiuses[i]
        		depth = depths[i]
        		direction = directions[i]
        		case direction
        			when "N"
        				dir = Geom;;Vector3d.new(0,0,1)
        			when "E"
        				dir = Geom;;Vector3d.new(-1,0,0)
        			when "S"
        				dir = Geom;;Vector3d.new(0,0,-1)
        			when "W"
        				dir = Geom;;Vector3d.new(1,0,0)
        			when "F"
        				dir = Geom;;Vector3d.new(0,-1,0)
        			when "B"
        				dir = Geom;;Vector3d.new(0,1,0)
        			else
        		group = nil
        			g.entities.each{|f|
        				if center.on_plane? f.plane then
        					group = g
        		gents = group.entities
        		active_faces = gents.grep(Sketchup;;Face);
        		circle_group = gents.add_group; cge = circle_group.entities;
        		edges = cge.add_circle(center, dir, radius);
        		circle_group.explode;
        		circle_face = (gents.grep(Sketchup;;Face) - active_faces)[0];
        		circle_face.pushpull(-depth)
        It works only if the cylinder's face is whole on the block.
        It "works", if I have two blocks on each other
        http://i.imgur.com/kAnKpQY.png
        • sdmitchS
          sdmitch
          In the second image, are both blocks in the same group? If so two new faces will be created and only one is being pushpulled.
            ado130
            No, they aren't. I know it's a problem and if I will do drill into 2 blocks, they need to be in the same group. But for now, the problem is first image. It looks like, pushpull tools pushpull the block and not cylinder(drill/notch).
            It works!! I had a little bug in my input file.
            So final code is
            		group = nil
            			g.entities.each{|f|
            					group = g
            		togos = []
            		edges.each{|edge| togos << edge unless edge.faces[0] }
            		model.active_entities.erase_entities(togos) if togos[0]
            Many many many thanks to both!
            Maybe a question about the second image, is it possible do it somehow?
            i.e.: Even if they are 4 blocks next to each (2x2 matrix) and create a hole in the middle.
            It occurred to me, try to apply this method twice (or more, if there will be more blocks next to each other).
            Or maybe 2nd solution, make a temporary group with all common groups/faces where will be a hole.
            Edit:
            So, I edited it
            		groups = []
            		i = 0
            			g.entities.each{|f|
            					groups.each {|x| next if g == x}
            					groups[i] = g
            					i += 1
            		groups = groups.uniq
            		countOfGroups = groups.length.to_i
            		countOfGroups.times do |i|
            			group = groups[i]
            			next if circle_face == nil
            			togos = []
            http://i.imgur.com/GDdGN4p.png
            It "works", but there is a problem, if I need do a drill over 3 (more) blocks.
            Or when I have 4 blocks, etc..
            http://i.imgur.com/o0xkiYw.png
            I found that after this circle_face = (gents.grep(Sketchup::Face) - active_faces), there are two faces, so I tried ".last", it helped, but still don't work at well.
            http://i.imgur.com/J8tQrBb.jpg
            Aby ideas?
              ado130
              It seems that it works. Is it correct way?
              Just one question, how can I delete the black lines?, or hide them.
              def drill(x, y, z, radiuses, depths, directions)
              	countOfDrills = x.length.to_i
              	countOfDrills.times do |i|
              		depth = depths[i]
              		case direction
              			when "N"
              			when "E"
              			when "S"
              			when "W"
              			when "F"
              			when "B"
              			else
              		groups = []
              		i = 0
              			g.entities.each{|f|
              					groups[i] = g
              					i += 1
              			group = groups[i]
              			activeFaces = gents.grep(Sketchup;;Face)
              			circleGroup = gents.add_group; cge = circleGroup.entities
              			circleGroup.explode
              			circleFace = (gents.grep(Sketchup;;Face) - activeFaces).last
              			next if circleFace == nil
              			normal = circleFace.normal
              			circleFace.pushpull(-depth)
              			deleteFace = (gents.grep(Sketchup;;Face) - activeFaces)[0]
              			if deleteFace.normal == normal then
              				deleteFace.erase!
              • sdmitchS
                sdmitch
                Try this
                 group = groups[i]
                 circleGroup.explode;
                 (gents.grep(Sketchup;;Face) - activeFaces).each{|circleFace|
                  next if center.distance(circleFace.bounds.center) > radius
                 remove = gents.grep(Sketchup;;Edge).find_all{|e|e.faces.length<2}
                 gents.erase_entities(remove.reverse)
                  ado130
                  It seems that it works too. Thanks!
                  But black lines are still there.
                  You have there "]", I think, it should be "}"?
                  • sdmitchS
                    sdmitch
                    Yes, you are right. Sorry about that.
                    The black vertical lines in the 'drill hole'?
                      ado130
                      Yeah, you're right, but I meant black lines in rectangular blocks (rather, all lines).
                      • sdmitchS
                        sdmitch
                        @ado130 said:
                        Yeah, you're right, but I meant black lines in rectangular blocks.
                        Well, if you didn't want them, why did you create then in the first place.
                        	group = groups[i]; group.make_unique
                        	activeEdges = gents.grep(Sketchup;;Edge);#<-- save active edges
                           #remove unused circle edges
                        	# hide vertical edges in drill hole
                        	soften = (gents.grep(Sketchup;;Edge)-activeEdges).find_all{|e|e.line[1].parallel?(dir) && !e.soft?}
                        	soften.each{|e|e.soft=e.smooth=true}
                        	# remove co-planar edges
                        	remove = gents.grep(Sketchup;;Edge).find_all{|e|(e.faces.length>=2 && e.faces.find_all{|f|f.normal.parallel?(e.line[1].axes[1])}.length==2)}
                          ado130
                          Sorry for the delayed response. It looks fine, thanks again!
                          http://i.imgur.com/TtoBovE.png
                          • 3 / 3
