    DC child component
    Scheduled Pinned Locked Moved Dynamic Components
    6 Posts 2 Posters 4.8k Views 2 Watching
      Jorgensen
      hi
      i have just started experimenting with dc, and i have a quick question.
      i have a group - "char", that contains two groups "seat", "legs".
      i have added a onClick behavior that i would like to hide / show the legs (just for testing).
      i thought i could do something like legs.SET("hidden", 0, 1), but that gives an error.
      i can ad the onclick behavior direct at the "legs", but when they are hidden, i can't click to show them again - so i thought the solution could be to add the behavior to the parent.
      is it possible to access childs from the main group?
      thanks
      jorgensen
      • P
        pcmoor
        create an attribute say called hide in the parent and give it a value 0, toggle this via the onClick with SET("hide", 0, 1).
        Then for hidden attribute value within the children(legs)
        hidden = parent!hide (or char!hide)
        example
        • P
          pcmoor
          can use SET("legs!Hidden", 0, 1) as direct reference as well
          example 2
            Jorgensen
            hi pcmoor
            thank you very much for your fast reply.
            i have opened your file and it works just fine!
            i have tried to replicate the same behavior to my own model, but i can't get it to work - though it seems that i have done exactly the same.
            could i ask you to test the file? it might just be a typeping error
            save.skp
            • P
              pcmoor
              hav't an explanation to why example 2 does not work, however able to fix using example 1
              will look into it tomorrow
              save.skp
              • P
                pcmoor
                the difference between my examples (hide.skp) and your model (save.skp) is the parent is a component in mine whereas yours is a group. It appears groups can't pass down a value, but rather they need to reference the parent.
