    DAE for Sdmitch or other coders!
    16 Posts 4 Posters 1.5k Views 4 Watching
    • soloS
      I see no problem
      • P
        pcmoor
        License type:Free/Make?
        I believe its a Pro feature
          ๐Ÿ˜ฎ
          At the start of the session I import the DAE file but...
          I have this! Do you think it's because i have SketchUp Make and not the PRO ?
          Same result with all possibilies of import DAE options!
          Can you post your cube as DAE exported from your SketchUp ?
            I don't believe!
            When I export objects from SU Make as DAE format
            I can import them at any moment as DAE format!
            Very mysterious! ๐Ÿ˜„
            • sdmitchS
              sdmitch
              No problem in SU2014 Free.
              http://sdmitch.blogspot.com/
              • sdmitchS
                sdmitch
                @pilou said:
                Can you post your own export DAE for see if i can reload it?
                sdm kub.skp
                sdm kub dae.zip
                  Curious I can reload it in 2015 but not in 2016! ๐Ÿ˜ฎ
                    Work in the 2015! ๐Ÿ˜Ž (import the DAE)
                    Seems existing in the 2016 but I see it only on the Structure! ๐Ÿ˜ฎ
                    Not on the screen! ๐Ÿ˜ฒ
                    (saved as 2014)
                    fantom.skp
                    • sdmitchS
                      sdmitch
                      (saved as 2014)
                      The model seems to be empty but Model Statistics shows that there is 1 ComponentInstance.
                      Interesting but I haven't a clue as to why.
                        I make some "New" and sometimes that works, sometimes not! (in 2016)
                        In any case I have not more since your dae file the Message "Empty component")
                        I believe the object is very tiny!
                        Maybe this explain that ?
                        • sdmitchS
                          sdmitch
                          [attachment=0:l0jt4utq]<!-- ia0 -->very_tiny.jpg<!-- ia0 -->[/attachment:l0jt4utq]
                          Very possible.
                            Seems make some "New" and take a more scaled new object resolve this curious problem! ๐Ÿ˜ฎ
                            I had the error message (empy component) but after some "New"
                            that is working! ๐Ÿ˜ฎ
                            Maybe also general Axes Position/ Screen ?...
                            • sdmitchS
                              sdmitch
                              To test if size is the problem, you can edit the .dae file and change line 99
                              <scale sid="scale">0.001 0.001 0.001</scale>
                              to
                              <scale sid="scale">1 1 1</scale>
                                I just test in take 1000 unities in the Start program : that makes 1 m inside SketchUp
                                And seems now working fine! ๐Ÿ˜Ž
                                  And Yep with your code that works like a charm! ๐Ÿ˜Ž
                                  The mystery is why that works for you and Solo for the original and not for me! ๐Ÿ’š
                                  Have you a secret resizing? ๐Ÿ˜„
