    DAE for Sdmitch or other coders!
    16 Posts 4 Posters 1.5k Views 4 Watching
      What is wrong with this DAE file format?
      When I import it inside SketchUp Make (2015 or 2016) I have : "Impossible to Insert an empty Component!"
      When I Open it in another program no problem! (MeshLab for example)
      Original cube deformed
      kub.zip
      • soloS
        I see no problem
        • P
          pcmoor
          License type:Free/Make?
          I believe its a Pro feature
            ๐Ÿ˜ฎ
            At the start of the session I import the DAE file but...
            I have this! Do you think it's because i have SketchUp Make and not the PRO ?
            Same result with all possibilies of import DAE options!
            Can you post your cube as DAE exported from your SketchUp ?
              I don't believe!
              When I export objects from SU Make as DAE format
              I can import them at any moment as DAE format!
              Very mysterious! ๐Ÿ˜„
              • sdmitchS
                sdmitch
                No problem in SU2014 Free.
                http://sdmitch.blogspot.com/
                • sdmitchS
                  sdmitch
                  @pilou said:
                  Can you post your own export DAE for see if i can reload it?
                  sdm kub.skp
                  sdm kub dae.zip
                    Curious I can reload it in 2015 but not in 2016! ๐Ÿ˜ฎ
                      Work in the 2015! ๐Ÿ˜Ž (import the DAE)
                      Seems existing in the 2016 but I see it only on the Structure! ๐Ÿ˜ฎ
                      Not on the screen! ๐Ÿ˜ฒ
                      (saved as 2014)
                      fantom.skp
                      • sdmitchS
                        sdmitch
                        (saved as 2014)
                        The model seems to be empty but Model Statistics shows that there is 1 ComponentInstance.
                        Interesting but I haven't a clue as to why.
                          I make some "New" and sometimes that works, sometimes not! (in 2016)
                          In any case I have not more since your dae file the Message "Empty component")
                          I believe the object is very tiny!
                          Maybe this explain that ?
                          • sdmitchS
                            sdmitch
                            [attachment=0:l0jt4utq]<!-- ia0 -->very_tiny.jpg<!-- ia0 -->[/attachment:l0jt4utq]
                            Very possible.
                              Seems make some "New" and take a more scaled new object resolve this curious problem! ๐Ÿ˜ฎ
                              I had the error message (empy component) but after some "New"
                              that is working! ๐Ÿ˜ฎ
                              Maybe also general Axes Position/ Screen ?...
                              • sdmitchS
                                sdmitch
                                To test if size is the problem, you can edit the .dae file and change line 99
                                <scale sid="scale">0.001 0.001 0.001</scale>
                                to
                                <scale sid="scale">1 1 1</scale>
                                  I just test in take 1000 unities in the Start program : that makes 1 m inside SketchUp
                                  And seems now working fine! ๐Ÿ˜Ž
                                    And Yep with your code that works like a charm! ๐Ÿ˜Ž
                                    The mystery is why that works for you and Solo for the original and not for me! ๐Ÿ’š
                                    Have you a secret resizing? ๐Ÿ˜„
