    [Plugin] BoolTools just released!
    84 Posts 38 Posters 79.1k Views 38 Watching
    • B
      boostabeats
      Thanks again TIG.
      Yes it is quite puzzling. I did exactly the same process to install it on my partners PC and it is working as expected. I haven't noticed anything not working... Yet ๐Ÿ˜„. Just strange it says it can't load something and then goes on working anyway ๐Ÿ˜„
      I'll see if Whaat replies again with more info when he gets time, and I'll PM him if not.
      Big thanks again TIG, it's much appreciated!
      • jeff hammondJ
        @boostabeats said:
        Thanks again TIG.
        yeah.. weird.. i've tried quite a few different things to get this to happen with booltools but i can't ..
        maybe you should try repairing permissions? (probably won't clear this up.. won't hurt to try though)
        i sort of wonder why the path in the error:
        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/booltools
        ..has Plugins capitalized because the sketchup plugins folder has always been lowercase..
        i also wonder if the ssd has anything to do with it? there's a little quirk in the osx sketchup launch sequence with plugins (main symptom being the plugin icons not showing up in the custom toolbar upon a fresh launch).. maybe your fast drive is messing things up further?? (though i doubt that.. i'm sure someone else would of brought this up by now)..
        so, in other words.. i have no clue as to what's going on ๐Ÿ’š
        • jeff hammondJ
          oh wait.. i found the problem..
          it's the 000_AdditionalPluginFolders.rb causing thisโ€ฆ remove it then the booltools load error will go awayโ€ฆ
            Well discovered !
            ๐Ÿ˜„
            • B
              boostabeats
              Thank a million Jeff!!!
              Works a treat now.
              As an extra bonus, OSCoolean now works perfectly as well! I had tried it in the mean time and it seemed to load fine but would not work on solids at all.
              Good stuff! I can't thank you all enough for taking the time to help.
              I look forward to learning more and more here.
              Cheers!
              • pbacotP
                I am trying out BoolTools to see if it will work for someone who doesn't have Pro. I am testing on a specific project to see if it can handle it.
                I am trying to cut vertical grooves into this coil tube. In the posted model I have already performed the subtraction with BoolTools three times. The object is still a solid (I had to do a little cleanup). The red component is to be subtracted from the yellow tube.Screen shot 2012-10-18 at 9.03.33 PM.png
                In the fourth attempt BoolTools fails. Can someone explain why or if BT or another plugin will ever be able to do this? This is a step that can also be done with "intersect with model", though it's more work. Several similar models need to be done--and I hope a methodology will develop that is useful to this person down the road.
                It does work fine with Solid Tools.
                Here is a screen shot of the results and the ruby console. So yeah, it worked, but also trashed the piece.Screen shot 2012-10-18 at 8.54.41 PM.png
                Thanks, Peter
                [PS: How does someone without "Pro" identify (and fix) solids?)
                BoolTools test.skp
                • cottyC
                  cotty
                  I don't know why, but it works if you grow the second group (in one direction with JPP) so that there are no coplanar faces anymore ...
                  BoolTools test_cotty.skp
                  my SketchUp gallery
                  • pbacotP
                    Thanks, Cotty! It would be easy enough to create those wedges with a larger circumference in the first place. There's no reason to have them co-planar, just been doing it that way with solid tools. That solves that question, I think. Peter
                    • N
                      NutsandBoltz
                      So this thread is probably dead, but it's worth a try, anyway. I cannot purchase BoolTools on Smustard. The plugin does not show up in the SMustard's product list, but the link that's been provided to it in multiple Sketchucation threads still works. Any idea how I could get a hold of it? My free trial will run out soon, and I'd rather have a boolean plugin if possible. I'm using Sketchup 2016. Thanks!
                      • W
                        Whaat
                        Hi NutsandBoltz,
                        I chose to temporarily take Booltools off the market as it was too unstable. I hope to relaunch an update in the near future but I can not guarantee when that will happen.
                        • 5 / 5
