    šŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    3D Truss Models
    1.5k Posts 31 Posters 935.0k Views 30 Watching
    • medeekM Offline
      medeek
      Sorry for all of the confusing terminology.
      Open Joist refers to a specific product produced by Barrette in Quebec Canada.
      There two main products are:
      Open Joist 2000
      Open Joist TriForce
      The thing that makes these floor trusses different from your standard MPC wood floor truss is that they use finger jointed webs instead of metal plates. The floor trusses are made entirely of wood and glue with no metal connectors.
      TRIFORCEĀ® Open Joist: Peace of Mind Underfoot
      The TRIFORCEĀ® open joist is a state-of-the-art product in the forefront of the construction industry.
      TRIFORCEĀ® Open Joist (www.openjoisttriforce.com)
      They come in standard sizes and lengths with a field trimmable end. They are installed similar to I-Joists using a rim board at the perimeter of the floor.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • JQLJ Offline
        JQL
        Pbacot,
        I meant I like them exposed not that they should be exposed.
        www.casca.pt
        Visit us on facebook!
        • medeekM Offline
          medeek
          Building code in the US usually requires some form of 1 hour rated covering (ie. 1/2" gypsum).
          design.medeek.com
          • JQLJ Offline
            JQL
            In here it's the same, however, if we can prove that the wooden structure will hold one hour more than needed, because of extra thickness, we don't need the covering. This can't be done with steel as heat makes it loose physical properties much faster than what happens with wood.
            www.casca.pt
            • medeekM Offline
              medeek
              For large agricultural buildings a double inverted truss can be employed to provide a large vaulted span for machinery:
              http://www.lakecountrytruss.ca/images/trusses/double_inverted_large.jpg
              I am wondering if this truss type is still commonly used by anyone for this type of application and whether it would be of interest, enough for me to add it into the growing list of trusses within the plugin.
              Also if anyone has any shop drawings they could send me that would be very helpful.
              design.medeek.com
              • medeekM Offline
                medeek
                A quick study of a double inverted truss by taking two 24' howe trusses and joining them to form a double truss. Note that the 4:12 pitch of the original trusses is maintained and the interior vault is exactly 8:12 pitch.
                http://design.medeek.com/resources/images/truss_su122_800.jpg
                View model here:
                3D Warehouse
                (3dwarehouse.sketchup.com)
                My question with this configuration is how the top and bottom chords at the peak should butt up? For example should the bottom chords at the peak have a double scarf cut or a single scarf cut? Some shop drawings would help in determining what is common practice.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.5.7 - 05.15.2016
                  • Added Scissor truss type, configurations: (4/2, 6/4).
                  • Structural outlookers (vert. & horz.) enabled under advanced roof options for Scissor (4/2, 6/4) truss types.
                  http://design.medeek.com/resources/images/truss_su123_800.jpg
                  View model here:
                  3D Warehouse
                  I also updated the pause in the truss selector GUI from 700 ms to 400 ms. Still more work to be done with raised heels and structural outlookers for some of these configurations but its getting close.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Coffer Truss Algorithm:
                    http://design.medeek.com/resources/truss/GEOMETRY/COFFER1_800.jpg
                    This is assuming that the coffer span is centered on the truss. A non-centered coffer algorithm could get significantly more interesting and difficult.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      In Oct. 7 last year I asked what is a bona fide extension in response to Juju's questions. That has led to about 57 releases and quite a large effort to put together a fairly decent plugin that can actually do what it purports to do which is create some accurate trusses and/or roof geometry.
                      I'm currently at 145 registered users with about ten times that in actual installations of the trial plugin. The number of registered users seems to have plateaued for now with maybe one or two new registrations per week.
                      I don't know if this is because the plugin exposure is fairly saturated or it simply is not quite good enough to entice an SU user to want to purchase the full version. The plugin is still missing a lot of features and there are quite a few more truss types and roof framing types that need to get added so my hope is that that is the reason for the plateau in the last few weeks.
                      If you have downloaded the trial version and have decided that more is needed before you are ready to upgrade to the full version please send me an email or message me with details, comments or suggestions on how I can get there. At least 40% of the current plugin is the result of requests from users so feedback has heavily factored into the development and will continue to do so.
                      I apologize that the manual is still not complete. Over the next month I am going to try and update the existing docs and start adding more content to bring it up to speed.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        This map shows where the Truss Plugin is being utilized:
                        404 - File or directory not found.
                        (design.medeek.com)
                        Note, this is only registered users and not all installations of the trial version. Also note that addresses have been dumbed down to City, State, Country so that the privacy of registered users is upheld.
                        design.medeek.com
                        • jujuJ Offline
                          juju
                          (design.medeek.com)
                          interesting to see!
                          • medeekM Offline
                            medeek
                            Version 1.5.8 - 05.22.2016
                            • Added metric input for Gambrel Attic truss type.
                            • Added a graphical user interface (GUI) for metric gambrel attic geometry input.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Gambrel Attic (metric) GUI
                              http://design.medeek.com/resources/images/truss_su125_800.jpg
                              I also show the industry standard feet-inches-sixteenths.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.5.9 - 05.29.2016
                                • Increased top chord pitch limit from 12/12 to 18/12 for the following Scissor truss types, configurations: (2/2, 4/4).
                                • Heel web logic revised to accommodate steeper pitches for bottom and top chords of scissor trusses.
                                • Increased top chord pitch limit from 12/12 to 18/12 for valley truss sets.
                                16/12:12/12 Scissor Truss with an 18" raised heel:
                                http://design.medeek.com/resources/images/truss_su126_800.jpg
                                Notice that the steep pitch of the bottom chord changes the way the heel web and bottom chord meet at the bearing point. The additional logic listed in the changelog notes deals specifically with this issue.
                                View model here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  I will probably add the symmetric cathedral truss type next:
                                  http://design.medeek.com/resources/images/truss_su127_800.jpg
                                  View model here:
                                  3D Warehouse
                                  The web configurations will use an "auto" triangulation algorithm similar to the tray truss type.
                                  design.medeek.com
                                  • JQLJ Offline
                                    JQL
                                    This has really got into an impressive level! Congratulations!
                                    www.casca.pt
                                    • jujuJ Offline
                                      juju
                                      indeed, help spread the word to help the man get more sales!
                                      • medeekM Offline
                                        medeek
                                        I've kind of been inching along recently. I've been beset with other concerns/jobs and I haven't had the time to really add some new innovative stuff to the plugin, mostly maintenance and refinements of existing truss types. My todo list has grown from a half page of notes to over 2 1/2 pages and it seems like I add something to it every other day. The dormer feature is something I really want to attack next but I need at least 3 good days of uninterrupted coding time to do it justice.
                                        What have I recently added that has garnered you attention? JQL
                                        Probably no one has noticed but I've started adding in links to the various screenshots within the Changlog. Sometimes a picture goes a long way in explaining some of these updates.
                                        Medeek Design Inc. - Medeek Truss Plugin Changelog
                                        (design.medeek.com)
                                        design.medeek.com
                                        • JQLJ Offline
                                          JQL
                                          The latest Gui image.
                                          It seems very complete. I just don't think the image displays metric units does it?
                                          www.casca.pt
                                          • medeekM Offline
                                            medeek
                                            I need to fix that. It currently is showing the typical ft-in-sixteenths on the preview image and not the metric units.
                                            design.medeek.com
                                            • 75
                                            • 76
                                            • 2 / 76
