    Creating Arcs: Interesting Problem, why?
    extensions
    3 Posts 3 Posters 932 Views 3 Watching
      designer7777
      I'm creating a few arcs, as will be shown in the example pic, with this code:
      c1 = Pt(0) 'cen
      r1 = Pt(1) 'rad
      sa = Pt(2)
      ea = Pt(3)
      wshShell.SendKeys "centerpoint = Geom;;Point3d.new" & "{(}" & c1 & "{)}" & vbCr
      wshShell.SendKeys "vector = Geom;;Vector3d.new 0,0,1" & vbCr
      wshShell.SendKeys "vector2 = Geom;;Vector3d.new 1,0,0" & vbCr
      wshShell.SendKeys "vector3 = vector.normalize!" & vbCr
      wshShell.SendKeys "model = Sketchup.active_model" & vbCr
      wshShell.SendKeys "entities = model.active_entities" & vbCr
      wshShell.SendKeys "edges = entities.add_arc " & "centerpoint," & "vector2, vector3," & r1 & "," & sa & "," & ea & vbCr
      (That code runs through 4 arcs in an array, pt changing per entity to be created.)
      The oddity is, a certain arc wants to reverse the orientation, all driven from the same code, all in the same overall loop of points. Just
      one arc does this, all the time. Same problem if I reverse the sa and ea.
      http://s20.postimg.org/rqcatc2zh/SU_ARC_Q.jpg
      Any idea why this is happening?
        driven
        does it work if just use ruby?
        • sdmitchS Offline
          sdmitch
          sa and ea should be angles not points in the .add_arc arguments.
          calculate the arc normal
          vector3=c1.vector_to(sa)*c1.vector_to(ea)
          http://sdmitch.blogspot.com/
