    New Graphics Card .. Now Have Warning!
    43 Posts 10 Posters 4.5k Views 10 Watching
    • JQLJ
      JQL
      @joe wood said:
      I put the CD in when the computer booted up so it got it's driver.
      And did you insert your GPU inside the computer case too? (just kidding here)
      Well but are you sure all your connections are right?
      You should download drivers from nvidia site instead of cdrom.
      If the driver insalled and everything is working everywhere else, then it's time to check if your nvidia settings are including sketchup (and layout) in your 3D applications list.
      Right click your desktop and choose nvidia settings. Then find wich 3D applications are being dealt with by the GPU. Add sketchup and layout if needed.
      www.casca.pt
      Visit us on facebook!
      • Joe WoodJ
        Joe Wood
        Yeah went and got the latest drivers and it's behaving well so far, and the Open GL Settings are back to Normal ..
        Looks like I got a 4 new drivers? I had it self detect which drivers I needed. Just assumed it was one 'driver'.
        Joe Wood
        woodsshop.com/
        • JQLJ
          JQL
          Sketchup's is the graphics driver
          www.casca.pt
          • Joe WoodJ
            Joe Wood
            Casca, I don't understand what you said?
            Joe Wood
            woodsshop.com/
            • jujuJ
              juju
              • Joe WoodJ
                Joe Wood
                I have a question, I set the resolution up at the Max 1900 x 1080, but the screen size, and text, is still a bit too large now.
                can I set the resolution even higher??
                Joe Wood
                woodsshop.com/
                  sonder
                  Probably not, your display will limit what is available. You are set to 1080P.
                  • sketch3d.deS
                    sketch3d.de
                    with digital monitors always use the native resolution of the display (here 1920 x 1080).
                    if Windows 7/8/10 you can check if you have fiddled with the text/icon size scaling of Windows by clicking at "Make text and other items larger or smaller" and adjust the scaling to a smaller value:
                    http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=abf6a6d1-a2b1-44b6-a2f9-ca132ae1250f
                    • Joe WoodJ
                      Joe Wood
                      That did it, I was set to Max,
                      thanks for the tip Sketch!
                      Joe Wood
                      woodsshop.com/
                      • Joe WoodJ
                        Joe Wood
                        Darn, I still have the 'missing text' problem in my exported images, with this jpg and with a tif,
                        that's why I got this new card, hoped it would fix this !
                        So what's happening with the text?
                        here's how it should look
                        and then here's the exported 6000 pixels wide Image
                        see the - Beam Connection - upper left is missing and the text lower left is smudged?
                        Joe Wood
                        woodsshop.com/
                        • JQLJ
                          JQL
                          Unfortunatelly that issue isn't related with your GPU but with the way Sketchup displays text and relates text position with camera position.
                          Some times that happens with exported sketchup jpgs and the only solution is to place text differently, often, pushing it away from camera.
                          www.casca.pt
                          • Joe WoodJ
                            Joe Wood
                            it's happening almost every image!
                            these block areas showing up in the text is the same issue,
                            never happened with my ol SUp Ver 5 πŸ™‚
                            Joe Wood
                            woodsshop.com/
                            • JQLJ
                              JQL
                              Never happens to me as I use Layout for that. I keep thinking I should dimension and leader in sketchup so it's nice I have these posts to remind me why I do not.
                              www.casca.pt
                              • Joe WoodJ
                                Joe Wood
                                chit, happening almost every image now .. 2d, or 3d images, doesn't matter
                                My Open GL is use Hdwr Asc and fast feedback,
                                my video card Program Settings set to Google SUp, what other Settings can I try?
                                Can I report this as a bug, to a support team??
                                Joe Wood
                                woodsshop.com/
                                • JQLJ
                                  JQL
                                  yes
                                  www.casca.pt
                                  • sketch3d.deS
                                    sketch3d.de
                                    check that "Camera > Perspective" is enabled and the FoV at "Camera > Field of View" is configured to 30 degrees (or higher).
                                    • Joe WoodJ
                                      Joe Wood
                                      No I have the FOV set to 35, thanks anyway, anyone else have any ideas?
                                      where would I report this bug??
                                      Joe Wood
                                      woodsshop.com/
                                      • jujuJ
                                        juju
                                        default FOV differs between Make and Pro versions, it's easy enough to set it the way you prefer though...
                                        • sketch3d.deS
                                          sketch3d.de
                                          @joe wood said:
                                          ...anyone else have any ideas?
                                          is the model very small/big in absolute dimensions or very far away from the origin?
                                          offic. SU Pro Technical Support Form
                                          • Joe WoodJ
                                            Joe Wood
                                            Nope, just an average sized model right at the origin.
                                            This happens with all my models, now that I've gone with SUp 2016 ..
                                            thanks for the link Sketch!
                                            Joe Wood
                                            woodsshop.com/
                                            • 1 / 3
