    Volume of Multiple Groups
    13 Posts 4 Posters 5.2k Views 4 Watching
    • E
      Enzay
      Hi Dan,
      Thanks foremost for such a great code and your use of comments; they're really useful for my learning.
      I saw TIG volume calc but it didn't give me a total volume of multiple groups and added geometry to the model I didn't want. The purpose of this script is to help me get a quantity take off. I use to use SketchUp pro at work with CSV export but I don't have access to that anymore.
      I also found that the units worked for inches but screwed up with SI units, which I'm using.
      It seems that this part of code is what sums all the volumes from each group. Where does the "arg" come from? Is that a just a variable that's an array of groups?
        def sum(arg)
            (@@subtot = @@subtot + arg) if arg.is_a?(Numeric)
          end #}
      It seems that somewhere it would be useful to call the current units being used and set those to the volumes of the groups?
        This one-liner
        v=0;Sketchup.active_model.selection.each{|e|v=v+e.volume if e.respond_to?(;volume)and e.volume>0};v
        Copy/pasted into the Ruby Console + <enter> returns the volume of selected 'solid' objects in cu" [non-solid groups etc are ignored as their volume == -1].
        You then need a converter to use other units...
        So instead of the closing ;v use a conversion factor...
        For cu'...
        ;v*0.000578703703703704
        For cu.m...
        ;v*0.000016387064
        etc...
        It's easily incorporated into a method/class/module code-set, with a menu or toolbar etc as needed...
        • Dan RathbunD
          Dan Rathbun
          However, TIG.. your cute one-liner, ignores groups that are not manifold, but DO contain nested manifold solids ?
          2nd.. He clearly asked for a Plugin, not a one-liner-copy-and-paste-into-console-command ...
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            That sum() is a private method, so it can only be called from inside the module.
            It's called by the other methods, and they supply the arg.
            See the iter() method, line 4, where it calls sum(e.volume)
            Yup...
            .. replace the line " #Sketchup::set_status_text @@subtot"
            .. with:
            units = mdl.options['UnitsOptions'] ui = units['LengthUnit'] if ui>0 convert = ['to_inch','to_feet','to_mm','to_cm','to_m'][ui] @@subtot = eval( "@@subtot.#{convert}.#{convert}" ) end
            nevermind I'll update the example...
            • Dan RathbunD
              Dan Rathbun
              But it really should look like this...
              Revised. Fixed output conversion for all units.
              require 'sketchup.rb'
              module AuYaXuan; end
              module AuYaXuan;;MultiVolume
                #{# CONSTANTS
                  VERSION = '1.0.1'  # 2012-02-29
                  TOPMENU = 'Plugins'
                  SUBMENU = '' # This can point to a submenu object
                               # created by another script.
                #{# MODULE VARIABLES
                  @@topmenu = UI.menu(TOPMENU) unless defined?(@@topmenu)
                  unless defined?(@@submenu)
                    if SUBMENU.empty?
                      @@submenu = @@topmenu
                    elsif SUBMENU.is_a?(Sketchup;;Menu)
                      @@submenu = SUBMENU
                    elsif SUBMENU.is_a?(String)
                      @@submenu = @@topmenu.add_submenu(SUBMENU)
                  @@subtot = 0 unless defined?(@@subtot)
                #{# PROXY CLASS
                class << self
                  private
                  #{ find( array_of_entities )
                  #  Returns an array of only Groups and,
                  #  Component Instances; or nil if none found.
                  def find(aoe)
                    found = aoe.find_all do |e|
                      e.is_a?(Sketchup;;Group) ||
                      e.is_a?(Sketchup;;ComponentInstance)
                    return found
                  end #}
                  #{ iter( group_item_array )
                  #  Recursive method that drills down into
                  #  nested Groups and Component Instances,
                  #  finding their manifold volumes.
                  def iter(items)
                    items.each do |e|
                      if e.manifold?
                        sum(e.volume)
                      else
                        if e.is_a?(Sketchup;;Group)
                          itp = find(e.entities)
                          iter(itp) if itp
                        elsif e.is_a?(Sketchup;;ComponentInstance)
                          itp = find(e.definition.entities)
                          iter(itp) if itp
                  end #}
                  #{ sum( number_to_add )
                  def sum(arg)
                  end #}
                  public
                  #{ main()
                  def main()
                    @@subtot = 0
                    mdl = Sketchup.active_model
                    # get itp (items to process)
                    itp = find(mdl.selection.to_a)
                    if itp # nil test
                      iter(itp)
                      if ui>0 # unit index
                      #Sketchup;;set_status_text @@subtot
                      msg = " Total Volume; #{Sketchup.format_length(@@subtot)} (cubic)"
                      puts(msg) unless $VERBOSE.nil?
                      UI.messagebox("\n\n"<<msg+"      ",MB_MULTILINE,'  MultiVolume')
                      #UI.messagebox(msg+"      ")
                    else
                      UI.messagebox("No Groups or Components in selection!      ")
                      return nil
                  end #}
                end # PROXY CLASS
                #{# RUN ONCE
                unless file_loaded?( File.basename(__FILE__) )
                  @@submenu.add_item("Volume Calcr") {
                    if Sketchup.active_model.selection.empty?
                      UI.messagebox("Selection is empty!      ")
                    else
                      main()
                  file_loaded( File.basename(__FILE__) )
              end # module AuYaXuan;;MultiVolume
                Dan
                I realize that he did ask for a 'plugin'; however, my 'one-liner' contains all of the basic elements he needs to make it himself. Your example of finding the units can of course be used to apply a conversion factor to the cu" volume - it might also be sensible to use sprintf to keep the d.p's in line if say it's to be 'outputted', rather that used in some later method as a float...
                It does ignore non-manifold objects, and whilst a group or definition might contain one or more manifold solids that is not processed; and I don't think that is really what was asked for either ?
                To burrow down into a group's entities, gets any nested groups/instances, see if they are manifold, get their volumes and apply any scaling transformations needed... is much more complex that the original question...
                If he wants to find the volume of somethings inside a group he can always edit the group, select them and thereby get their volumes separately...
                • Dan RathbunD
                  Dan Rathbun
                  The volume() method appears to take any scaling into account.
                  So what do we do ? Ignore and throw out his example ? Should I erase the cleaned up working plugin example I posted above ?? (Did you even try it?)
                  Do we yank ourselves over to the TIG way of doing this ??
                  Oh OK... sorry folks! TIG says ya'll have to do things the hard, slow way. πŸ˜›
                  And.. don't need to use sprintf for now, as there's only 1 total volume value returned. (Maybe later if he writes a report generating method.)
                  • E
                    Enzay
                    I see now how the inter gives the volume of the entity to the sum method which adds it to the total amount.
                    I suppose TIG's one-liner is adapt for someone familiar with quickly coding into the ruby console to get a result. I am, not so advanced and prefer to see a ruby script so that I can understand what is happening. Not to say that I specifically requested a ruby, but It does help significantly that the script recognizes nested groups which, as rubys are prone to do, saves time and effort.
                    I appreciate both your input to helping solve my problems. Thank you very much.
                      I think the object.volume method does return the 'scaled-volume' of the object... but does it take into account the scaling of that volume's container[s] ?
                      I suspect not...
                      If you are happy with an #all bells and whistles# volumes getter, by delving into nested objects and getting all the right results, that's fine by me - my quick one-liner was simply to show how to get basic volumes without too much angst. It's no different to typing code into a 'method' in a script file - the script's carriage-returns are just shown as ';' instead...
                      • F
                        farukc
                        Thankyou Dan!
