    Assigning a default material.
    6 Posts 5 Posters 1.4k Views 5 Watching
      Deanby7
      I am trying to add a Brick_Antique material to a face with Ruby. The material is in the model already, but will not apply the material with this code....
      mats = Sketchup.active_model.materials
      brick = mats['Brick_Antique']
      oface.material = brick
      However, if I make the Brick material current in the model and then use this....
      current = Sketchup.active_model.materials.current
      oface.material = current
      It works!
      I assume from this that the display name cannot be used to reference the material. So how would I get the internal name of any in-model material if you only know its display name?
      • sdmitchS Offline
        sdmitch
        It works!
        This should
        brick = mats['[Brick_Antique]']
        http://sdmitch.blogspot.com/
          driven
          or use grep
          oface.material = Sketchup.active_model.materials.grep(/Brick_Antique/)
            A material has two 'names'.
            If you have created it then they'll be the same,
            material.name >>> "SomeName" material.display_name >>> "SomeName"
            but if you have imported it from an external collection then they are likely to be different - e.g. inside []...
            material.name >>> "[SomeName]" material.display_name >>> "SomeName"
            Another way to set it by ' display_name' [i.e. what you can read] would be...
            mats = model.materials name = 'Brick_Antique' mat = nil mats.each{|m| if m.display_name == name mat = m break end } oface.material = mat
            In you case I assume it's relating to your 'hole making' ?
            If you want to match the new reveals' material to the cut face, then you don't even need to know the material's name at all.
            Let's assume the face you are making the hole in is referenced as ' face'.
            Then use
            omat = **face**.material oface.material = omat
            Which takes a direct reference to the material [if any] - sidestepping any need to know its name/display_name at all...
              Deanby7
              The last code is exactly what I want. Thanks.
              • Dan RathbunD Offline
                Dan Rathbun
                Still another way:
                mats = model.materials name = 'Brick_Antique' mat = mats.find {|m| m.display_name == name } oface.material = mat
                I'm not here much anymore.
