    [Plugin] EdgeInspector - v1.2a - 12 Oct 14
    42 Posts 18 Posters 43.5k Views 18 Watching
    • BurkhardB
      Burkhard
      For a magnifier tool I asked years before when Pixdim comes out
      Thanks for it!
      http://www.ia-plus.de
      • fredo6F
        NEW RELEASE: EdgeInspector v1.2a - 12 Oct 14
        EdgeInspector 1.2a is a major release which is fixing a number of problems with 3 tools: Lost Junctions, Tiny Gaps and Tiny Edges.
        This release provides a more accurate and relevant inspection and fixing:
        • Tiny Edges are now detected and fixed in groups (loop, hook and sequence)
        • Tiny Gaps are detected more adequately and fixed either by moving vertices or by moving the whole connected shapes (to keep the integrity of geometry)
        • Lost Junctions receives a more accurate treatment
        See main post on EdgeInspector for more information
        See main post of this thread for Download of FredoTools.
        • F
          floriane_mvdb
          Hello Fredo 6, thank you for this plugin that seems to be really awesome!
          I don't know if it's the good place to ask for some help using this tool, didn't find any subject about it in the forum.. The problem is that everytime i try to fix the defects calculated in Edge Inspector, i get the same error message saying : error during inspection, Cannot convert argument to Sketchup::Point3d (with a list of errors)
          What could i do to solve the problem ?
          Thank you
          • fredo6F
            Thank you
            In order for me to help, could you post or send me the error full text, either as a copy paste, or by exporting the file as a txt.
            Could you also tell me which correction tool(s) you were using.
            I may also need the model, incase I do not see the problem from the error log.
            • P
              pipinek
              Empty window.
              Greetings,
              When I select some edges and apply the Edgeinspector tool I have an empty window with no content:
              http://screenshot.net/lzdn6tp.jpg
              What could be wrong here (except the problem between my chair and a screen)?
              Thank you in advance.
              • fredo6F
                @pipinek
                The attached image is missing.
                • P
                  pipinek
                  Hello Fredo,
                  It is quite strange, the image is visible on my equipment:
                  http://s32.postimg.org/r4yuq6dv9/image.png
                  • fredo6F
                    @pipinek,
                    There must be a bug. Could you please open the Ruby Console before launching EdgeInspector and tell me the error you see.
                    • P
                      pipinek
                      Thanks Fredo for your reaction,
                      Here is the result, well no result at all. The Ruby Console is empty.
                      I have launched RConsole, selected a rectangle and activated Edgeinspector tool.
                      http://screenshot.net/095oxs2.jpg
                      PS
                      I have just noticed that on the other PC with apparently with the same plugin set and configuration (SU 2015) the plugin works well.
                      Bizarre. Is the any potential conflict to take into consideration?
                      If yes what shall I check?
                      Thank you in advance for your kind assistance Fredo.
                      • fredo6F
                        Did you try without edge preselection ?
                        • P
                          pipinek
                          Do you mean Whole Model?
                          Same results. Empty Edge Inspector box.
                          I have found the following in Ruby Console (I typed before several SU sessions: 'edgeinspector' - the Ruby Content has stil remained there):
                          edgeinspector
                          Error: #<NameError: undefined local variable or method edgeinspector' for main:Object> <main>:in <main>'
                          SketchUp:1:in `eval'
                          Finally I have managed it to work by a crazy chance.
                          I have change something in option shrink... by clicking on a tiny square. Now I have an option bar for each tool including Edge Inspector box content.
                          http://screenshot.net/r577nc6.jpg
                          I have another issue with Drawalong tool though.
                          I cannot assign a letter/keyboard shortcut to it.
                          Any combination I have tried (my prefered a letter D) when typed it opens a web browser with a youtube page with instruction video.
                          Is there any solution to the issue, any possibility to have a key shortcut to Drawalong tool?
                          • fredo6F
                            I think that in the Preferences - Short Cut dialog box, you filter with "DrawAlong". This shows the Video menu.
                            You should filter with "Draw Along", with a space, which will display the main command.
                            • P
                              pipinek
                              Huge thanks.
                              It does work as you have described.
                              But you have to admit that its a too tricky for an everyman user. The tool name is DrawAlong (no space).
                              I will be aware such possibilities in the future.
                              Best regards with my gratitude for your responses.
                              • fredo6F
                                Glad it works now.
                                Actually, the best is to look first at the menu text and apply the filter accordingly.
                                • P
                                  pipinek
                                  Indeed this is the best way.
                                  Alas, I am not the one.
                                  Thank you once more for your assistance and your marvellous works.
                                  • K
                                    karasupike
                                    thank youu!!
                                    • B
                                      bharralure
                                      Bonjour,
                                      Edge Inspector v3.3b semble ne pas fonctionner correctement sur SU 2019 (Installé depuis SketchUcation).
                                      Au lancement de l'outil, la fenêtre affichée est incomplète, tel que le montre la capture d'écran jointe.
                                      J'ai désinstallé FredoTools, puis réinstallé sans succès.
                                      Je joins également le rapport de la console Rubis, en espérant que cela aide.
                                      D'avance merci pour toute aide.
                                      EdgeInspector_ErreurInstallation.txt
                                      • fredo6F
                                        Thanks for advising. I fixed it in FredoTools v3.3c. This is actually an incompatibility introduced with the new version of Ruby that is shipped with SU2019.
                                        • B
                                          bharralure
                                          Effectivement, la version 3.3b fonctionne parfaitement dans SU 2018, mais je viens d'installer la version 3.3c dans SU 2019, et tout est rentré dans l'ordre.
                                          Encore un grand MERCI pour la rapidité de cette mise à jour, et pour l'ensemble de votre travail.
                                          • C
                                            ct103stu0
                                            Could not detect and/or fix these tiny gaps in diagonal lines. See attached file (screen shot). What am I doing wrong?
                                            Example screen shot
                                            • 2 / 3
