    Projecting a Material
    2 Posts 2 Posters 369 Views 2 Watching
      garystan
      Hi everybody :
                  Can a projected material be reversed ?  The reason I ask is that,  I'm making a triangular banner. On the "front" side (with the point facing to the right),  I can easily paint it on. Then "position"  the material.  But, I'd like to be able to "paint" the reverse side so I can use the banner in either (horizontal) direction. And be able to put the material on this reverse side....in the reverse horizontal direction.  That way I can use the banner pointing either right or left.   Thanks
        garystan
      • pbacotP Offline
        Yes. If you sample the projected texture on the first side then paint it on the back, it will show reversed.
