    Extend by amount plugin
    11 Posts 4 Posters 1.9k Views 4 Watching
    • C
      camoncamon2001
      Hi to all!
      I'm searching for a plugin that extend multiple lines at once in his vector direction and in both sides with a predefined amount as in attached image.
      Does anyone knows something like this?
      Thanks in advance.
      CC
      • BoxB
        At a rough guess from your image, Tigs smart offset might help you.
        • C
          camoncamon2001
          The should work independently from the presence of a face and with unconnected lines too
          • sdmitchS
            sdmitch
            @camoncamon2001 said:
            Hi to all!
            Thanks in advance.
            CC
            Sketchup won't let you "extend" an edge associated with a face because it automatically breaks lines where they cross. The extension will have to be an added edge at each end point like this.
            mod = Sketchup.active_model
            ent = mod.active_entities
            sel = mod.selection
            unless sel.empty?
              dst = UI.inputbox(["Extend;"],['1'.to_l],"Extend all Edges")
              if dst
                sel.grep(Sketchup;;Face){|fac|
                  fac.edges.each{|e|
                    sp,v=e.line;ep=e.end.position
                    ent.add_line(sp,sp.offset(v,-dst[0]))
                    ent.add_line(ep,ep.offset(v,dst[0]))
            http://sdmitch.blogspot.com/
            • C
              camoncamon2001
              Hi to all!
              Thanks in advance.
              CC
              [attachment=0:22irlvoa]<!-- ia0 -->Extend Edges.gif<!-- ia0 -->[/attachment:22irlvoa]
              > sel = mod.selection
              > unless sel.empty?
              >   if dst
              >       fac.edges.each{|e|
              >   end
              > end
              Great! How to use with separate lines, not face?
              • sdmitchS
                sdmitch
                For Edges
                sel = mod.selection
                unless sel.empty?
                  dst = UI.inputbox(["Extend;"],['12'.to_l],"Extend all Edges")
                  if dst
                    sel.grep(Sketchup;;Edge){|e|
                • C
                  camoncamon2001
                  Thank you! Perfect!
                  • PixeroP
                    Pixero
                    Would it be possible with a version that extended edges on faces like in this image to quadify surfaces?
                    Let's say you have a wall with a door and some windows.
                    The script would try to extend edges to outer loop.
                    Inner loops would try to find closest point.
                    Hopefully resulting in a quad face surface.
                    • sdmitchS
                      sdmitch
                      [attachment=0:311e78k8]<!-- ia0 -->wallsegments2.jpg<!-- ia0 -->[/attachment:311e78k8]
                      Looks simple enough but IMHO virtually impossible to code.
                      • PixeroP
                        Pixero
                        Would it be possible to make it simpler with just extending edges until it meets a edge?
                        For a case like in the image above that would work for all but one. (The diagonal edge.)
                        • sdmitchS
                          sdmitch
                          Yes, it is the diagonal edges that complicate the problem but I'm still thinking about it.
