    SU Pro 64bit & Make 32bit parallel
    6 Posts 3 Posters 893 Views 3 Watching
    • F Offline
      faust07
      Is it possible without any problems, to install and run SketchUp Pro 16 64bit and Make 32bit parallel on one system?
      • ely862meE Offline
        ely862me
        From what I know they won't work on the same system.
        Elisei (sketchupper)
        Come and See EliseiDesign
        • F Offline
          faust07
          My problem is that I want to purchase SU Pro 2016. I want to use the 64-bit version and its benefits for normal professional work. But for the use of SketchyPhysics I need the 32-bit version. For this SU Make 2016 would be sufficient. So it would be good if I could run both parallel. Is there a solution? The solution is crucial for the purchase and the jump from SU 8 Pro to SU 16 Pro.
          • ely862meE Offline
            ely862me
            If you don't use the Sketchyphysics in a commercial way you can run the free version of 2015 on 32 bit.
            • F Offline
              faust07
              Thank's for the help. That could be a solution. But may be I buy SU Pro 2016 32-bit to spare the permanent converting between the versions.
              • sketch3d.deS Offline
                sketch3d.de
                @faust07 said:
                ...use the 64-bit version and its benefits for normal professional work.
                there is no benefit besides using render plugins relying heavily on the memory management of SU.
                actually some video drivers (AMD) and their 64-bit OpenGL support do not work flawless with SU x64.
