    SketchUp Debugging for Notepad++
    22 Posts 6 Posters 4.6k Views 6 Watching
      Jim
      @jolran said:
      This only works with Sketchup 2014/ Ruby 2, right ?
      Correct.
      • jolranJ Offline
        jolran
        Ok, thanks.
          Jim
          Updated the .zip to v0.2
          • Added a new margin for Breakpoints. Simply click on margin to add/remove breakpoints. (Breakpoints are represented as a red arrow.)
          • Updated toolbar (Tooltips are not supported, unfortunately.)
          • Added better exception handling and messages.
            Jim
            No interest?
            • jiminy-billy-bobJ Offline
              jiminy-billy-bob
              Sure there is!
              I've not had time to use it, but it seems promising 😉
              • jolranJ Offline
                jolran
                ditto.
                • W Offline
                  woodshop
                  does the plugin work for SU 2015?
                    Jim
                    The plugin is for the editor Notepad++. The SketchUp Ruby Debugger works with SketchUp 15, so yes you should be able to connect Notepad++ to the SketchUp debug server.
                    • Y Offline
                      ying2014
                      I have a question,the notepad++ v6.6.2.is old ,how can I use the script for my notepad
                        Jim
                        Hi Ying,
                        I haven't tried it in years. This was more a proof-of-concept than a finished plugin. I was disappointed with the poor integration of the plugin with the Notepad++ user interface. The plugin is written in Python and uses the PythonScript plugin for Notepad++.
                        I have just now been trying to get this to work on version 6.9.1 but so far have not had success getting Python Script to work.
                        • Y Offline
                          ying2014
                          Hi Jim, Thanks for your answer,I'm looking forward to it can succeed.
                            Jim
                            You can try it by downloading this file.
                            Extract the .zip and start Notepad++ by clicking the notepad++.exe file inside.
                            Open a Ruby extension to debug. Press F5 to start SketchUp in Debug mode.
                            Press the SketchUp Icon in the toolbar - this will start SketchUp and add a new margin in the editor - click on the margin to set breakpoints.
                            • Y Offline
                              ying2014
                              hello.jim,it can't work well
                              Connecting to SketchUp..
                              Traceback (most recent call last):
                              File "plugins\Config\PythonScript\scripts\SketchUp\init.py", line 2, in <module>
                              sudb.init()
                              File "C:\Users\zyq\Downloads\npp-6.9.1+skpdbg\plugins\Config\PythonScript\scripts\sudb.py", line 100, in init
                              connect()
                              File "C:\Users\zyq\Downloads\npp-6.9.1+skpdbg\plugins\Config\PythonScript\scripts\sudb.py", line 111, in connect
                              except socket.error (value, message):
                              NameError: global name 'value' is not defined
                              sending: v l
                              File "plugins\Config\PythonScript\scripts\SketchUp\local-vars.py", line 2, in <module>
                              sudb.local_vars()
                              File "C:\Users\zyq\Downloads\npp-6.9.1+skpdbg\plugins\Config\PythonScript\scripts\sudb.py", line 327, in local_vars
                              send("v l")
                              File "C:\Users\zyq\Downloads\npp-6.9.1+skpdbg\plugins\Config\PythonScript\scripts\sudb.py", line 160, in send
                              sock.send(msg)
                              socket.error: [Errno 10057] ԉԚ͗ޓؖûԐlޓҢȒ(ձʹԃһٶ sendto ַԃע̍˽ߝѨ͗ޓؖʱ)
                                Jim
                                It looks like SketchUp is not running the debug server. Start SketchUp from Notepad++ by pressing the F5 key. This launches SketchUp using this command line:
                                Sketchup.exe -rdebug "ide port=1234"
                                If you need to change which version of SketchUp, or the location of SketchUp then edit the "shortcuts.xml" file in the NPP folder.
                                SketchUp must be started with the debug server enabled before pressing the SketchUp icon from the editor.
                                Again, this debugger is never going to work well because of limitations in PythonScript for Notepad++ and in the SketchUp debug server.
                                I have tried to fix your error. Extract the file "sudb.py" and replace it in the "plugins\Config\PythonScript\scripts" folder.
                                sudb.zip
                                • Y Offline
                                  ying2014
                                  Sorry,it don't work:
                                  socket error: [Errno 10061]
                                  Could not connect to SketchUp.
                                    Jim
                                    Here is a link to Windows socket errors.
                                    10061 Connection refused.
                                    No connection could be made because the target computer actively refused it. This usually results from trying to connect to a service that is inactive on the foreign host—that is, one with no server application running.
                                    How are you starting SketchUp?
                                    • Y Offline
                                      ying2014
                                      hello ,jim
                                      I use Press F5 to starting Sketchup
                                        Jim
                                        @ying2014 said:
                                        hello ,jim
                                        Which version of SketchUp is being launched? Is the file "SURubyDebugger.dll" located in the correct folder (as in the image for SketchUp 16?)
                                        Does SketchUp start completely, or does it freeze? When started with the debug server, SketchUp will appear to freeze while it is waiting for a "start" or "continue" command from Notepad++.
                                        Is you firewall set to allow connections to SketchUp?
