SketchUp Debugging for Notepad++
hello ,jim
I use Press F5 to starting Sketchup -
@ying2014 said:
hello ,jim
I use Press F5 to starting SketchupWhich version of SketchUp is being launched? Is the file "SURubyDebugger.dll" located in the correct folder (as in the image for SketchUp 16?)
Does SketchUp start completely, or does it freeze? When started with the debug server, SketchUp will appear to freeze while it is waiting for a "start" or "continue" command from Notepad++.
Is you firewall set to allow connections to SketchUp?
